What is the acceleration of a plane based on a pendulum's angle?
  • Thread starter Thread starter tjackson3
    Frame Pendulum
The problem involves analyzing the acceleration of a jet airplane based on the angle of a pendulum held inside the aircraft. The context includes a pendulum of known length and mass, with specific angle measurements provided. The participants are exploring the relationship between the pendulum's angle and the airplane's acceleration.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss various approaches to determine the acceleration, including the use of gravitational components and the relationship between tension and acceleration. Some express uncertainty about their understanding of the forces involved and the correct application of equations.
The discussion is active, with participants offering guidance on visualizing the problem through diagrams and identifying forces acting on the pendulum. There is a suggestion that the relationship between acceleration and the angle can be simplified, but no consensus has been reached on the correct method or final values.
Participants are working within the constraints of a homework problem, which may limit the information available for solving the problem. There is an emphasis on understanding the forces at play rather than arriving at a definitive solution.
tjackson3
Granted, I may be thinking too much into this.
You are sitting in a jet airplane as it accelerates at a constant rate down the
runway. Being a good physics student you hold the string of a small pendulum of length
l = 0.75m and mass m = 1 kg. You then measure the angle between the string and a
vertical line and [itex]\theta = 37^{\circ}[/itex]. Assume [itex]\sin\ 37 = 3/5; \cos\37 = 4/5; \tan\ 37 = 3/4[/itex], and take [itex]g = 10 m/s^2[/itex]
a.) What is the magnitude of the acceleration of the plane?
b.) What is the tension on the string?
Nonrelativistic coordinate transformation: [itex]x' = x - vt[/itex]
There are a couple of ways I can see doing this, but I think both show that I don't completely understand what's going on. My first thought was that the net acceleration is zero, meaning that [itex]a = g\cos\theta = 8 m/s^2[/itex]. This would make the tension [itex]\sqrt{m^2g^2 + mg^2\cos^2\theta} = \sqrt{100 + 100.5625} = \sqrt{200.5625}[/itex] but I don't think that's correct.
Alternatively, it could involve circular motion, although I have no idea what to plug in for the velocity in the centripetal force equation.
Thanks for the help!
I suggest you to start every problem-solving with a figure. Here you have to show the forces acting on the moving object, the bob of the pendulum. When the pendulum is stationary with respect to you, it moves together with the aeroplane, with a constant horizontal acceleration. As the bob is connected to the string only, the horizontal component of the tension T provides the force needed to this horizontal acceleration. The other force is gravity, it cancels with the vertical component of T.
ehild
Yes, it is so simple...
ehild
  • · Replies 21 ·
  • · Replies 20 ·
