Mysterious Window: Force It to Move or Find the Process Name?
  • Thread starter Thread starter grady
    Window
The discussion revolves around a user experiencing an issue with a window that appears at the bottom of the screen and cannot be moved. Participants explore potential methods to identify the process associated with the window and ways to force it to move or hide it. The conversation includes technical troubleshooting, user experiences, and speculative concerns about security.
  • One participant expresses concern about being hacked due to a window that cannot be moved and suggests that spyware might be involved.
  • Another participant recommends using ALT and TAB to bring the mystery window to the top of the task manager list and suggests closing applications to troubleshoot the issue.
  • A different participant notes that the window is not movable and mentions that right-click options are faded out, indicating a potential software issue.
  • One suggestion includes checking if the taskbar is set to always be on top and using a program to hide the window programmatically.
  • Participants discuss the possibility of the window being an advertisement loader and inquire about the frequency of advertisements experienced by the original poster.
  • There are mentions of searching for the process name in the task manager and registry to identify the source of the window.
  • Concerns are raised about the potential for hacking, although some participants believe it is unlikely due to the presence of a firewall.
Participants do not reach a consensus on the nature of the window or the best approach to resolve the issue. Multiple competing views and suggestions are presented, reflecting uncertainty about the cause and solution.
Participants express varying levels of technical knowledge and familiarity with task manager functionalities, which may influence their proposed solutions. There is also uncertainty regarding the identification of the window and its implications for system security.
This discussion may be useful for individuals experiencing similar issues with unmovable windows, those interested in troubleshooting software problems, or users concerned about potential security threats on their computers.
grady
Why is the top of this window appearing at the bottom of the screen? Am I being HACKED! OMG I can't move the window and there isn't anything but the normal spyware that the cable company installs in the task manager. Does anyone know how to force a window to move or how I might link this window to a process name?
http://members.cox.net/gradyfield/hacked.jpg
Computer science news on Phys.org
First thing I'd do is close all applications.
Press ALT and TAB to switch to that bring the mystery window to the top of the task manager list.
Then, hit CTRL-ALT-DEL to bring up the task manager.
Record the name of the open window, which hopefully will be at the top of the list in Task Manager. Then, using task manager, close the window.
Look in your startup folder under program files and see if anything matching that window name is in there.
I take it you are not able to move the window into view. I've seen things like this, seems a lot of times it is just an auto advertisment loader that sites launch on your pc as a popup window so that they can bombard you with advertisment popups.
Tell me this, do you get a lot of adverts?
Thanks for the tip on the task manager. I didn't know the current window was put at the top. The window isn't movable, and if I right click it, Move and Restore (faded out ) are on the menu. If i click move, the 4 directional arrow comes up for a second or two and the window disappears.
I have a firewall installed, so even if it were a program to beckon popup adds to the desktop, either it or they would be stopped I think. The next time the window comes up i'll tell you what the process name is, it comes up at least once a day.
If what annoys you is seeing the window, and not is precense, you can :
1-Check that the taskbar's always on top is enabled.
2-Use a program to catch the window's ClassName, then make a program to hide that window on start up (programatically). This can be done in VB (if it really annoys you, i can do this for you).
Originally posted by grady
Thanks for the tip on the task manager...
How did task manager identify the window?
PROGRAMMING TO GET RID OF SPAM Talk about swatting a fly with a tank! Just control,alt,del and get the file name. Do a search both through start>find> files or folders, and also do a search of the registry. You can do this by going to start> run and typing in regedit. Then hit F3, which brings up the search menu, and do a search for the file in there. It's either in the windows startup folder, in the HKLM>SOFTWARE>MICROSOFT>WINDOWS>CURRENT VERSION<RUN directory in the registry, or both.
Edit: not to scare you, but you want to get it off there. Although it's unlikely, it's always possible someone's attempting to hack your PC, though it's unlikely given that you have a firewall.
  • · Replies 30 ·
  • · Replies 123 ·
21K
  • · Replies 20 ·
17K
9K
  • · Replies 19 ·
15K
  • · Replies 24 ·
