Register to reply
Calculating Yield Strength using a Load vs. Displacement Curve
by ginarific
Tags: curve, displacement, load, strength, yield
Share this thread:
ginarific
#1
Apr7-10, 12:54 PM
P: 4
Hi,
This question came up on my midterm and I had no idea how to answer it without redrawing the entire curve as a stress vs. strain curve (which obviously took too long to do).
Anyway, I'm just requesting a general procedure, not a numerical answer. If you had a Load (y-axis) vs. Displacement (x-axis) curve, how do you calculate the yield strength? I know for a stress vs. strain curve, you have to have a 0.2% (0.002) offset, but my Professor told me that the offset is not of the same value in a Load vs. Displacement curve (which makes sense).
However ... what <i>is</i> the actual offset supposed to be? Is there a formula to calculate it?
Any help would be very much appreciated! :)
Thank you,
Gina
Phys.Org News Partner Engineering news on Phys.org
Comfortable climate indoors with porous glass
Crash-testing rivets
Customized surface inspection
Astronuc
#2
Apr7-10, 05:33 PM
Admin
Astronuc's Avatar
P: 21,827
The 0.2% (0.002) is a value of strain, which is arbitrary, but it covers somewhat the uncertainty of when a given material actually departs from the purely linear (elastic) relationship between stress and strain.
Let l = length, then strain ε = (l - lo)/lo, where lo = original length (usually the gauge length). Also, the displacement, d, is given by (l - lo), so strain ε = d/lo.
Similar the stress, σ, is just the load/force F divided by area A, i.e. σ = F/A, where A is constant until the specimen reaches UTS, which corresponds to the limit of uniform elongation, and necking begins.
Now back to length/displacement -
with ε = (l - lo)/lo, one rewrites the equation as ε = l/lo - 1, and reorganizing the terms, l = lo (1+ε),
so the length equivalent to the strain offset of 0.002 is just l = lo*1.002, or d (0.002) = 0.002 lo.
General_Sax
#3
Sep13-10, 11:03 PM
P: 450
So, if I have the following data:
A = 0.36m2
F = 9800N @ 0.2% offset
Then [sigma] = 9800/0.36 = 2.7*104 Pa ??
I just have a problem regarding the constant area. Wouldn't the cross-sectional area be decreasing while the object is strained (stretched)?
stewartcs
#4
Sep14-10, 12:25 PM
Sci Advisor
stewartcs's Avatar
P: 2,283
Quote Quote by General_Sax View Post
A = 0.36m2
That gives you the Engineering Stress (which is always a function of the original cross-sectional area).
Yes. The stress in this case is called the True Stress and is a function of the instantaneous minimum cross-sectional area of the specimen.
CS
Register to reply
Related Discussions
Calculating the dead load (G) and live load(Q) of this tunnel - civil engineering que Engineering, Comp Sci, & Technology Homework 4
Need Help with Yield Strength for FEA Engineering Systems & Design 3
Yield strength Materials & Chemical Engineering 2
Yield strength Materials & Chemical Engineering 8
Yield Strength Introductory Physics Homework 3
