Hydrostatic force acting on beam
The discussion focuses on calculating the hydrostatic forces acting on a beam designed to support a water tank. The beam consists of two unequal angle steel sections, specifically 75x50x6 mm, bolted together with M10 bolts. The user seeks to determine if the M10 bolts can withstand the forces, noting that the water load does not significantly impact the bolts. The conversation emphasizes the importance of analyzing maximum shear and bending stresses at the fixed end of the beam.
  • Understanding of hydrostatic pressure principles
  • Knowledge of structural engineering concepts, specifically shear and bending stress
  • Familiarity with steel section properties and bolted connections
  • Experience with calculating forces in structural components
  • Research "Hydrostatic pressure calculations for tanks"
  • Study "Shear and bending stress analysis in beams"
  • Learn about "Bolted joint design and failure modes"
  • Investigate "Material strength properties of M10 bolts"
Structural engineers, civil engineering students, and professionals involved in the design and analysis of water tanks and supporting structures.
Whatamiat
Attached is the problem i am trying to get to grips with along with my current line of understanding,
The column seen is a side section slice from the design of a water tank.
The column is designed to take the load of the water.
The column is designed with 2 unequal angle 75x50x6 steel sections.
These sections are bolted together using m10 bolts at the distances shown in the attachment.
I am trying to find the forces acting on the bolts in order to confirm a m10 bolt is stong enough.
Is my line of thought right here?
Or am I missing something alltogether?
The water doesn't impose any significant load on the bolts. Both angles want to move together the same amount and the bolts don't do anything to prevent that movement.
Depends on what your bolts are bolted up to.
The other thing you can do is look at the stresses in the beam. Find your maximum shear and bending stress, which is at the fixed end.
  • · Replies 36 ·
