Where does all this spacetime curvature come from?
The discussion revolves around the nature of spacetime curvature as described by General Relativity (GR), questioning the evidence for mass curving spacetime and the implications of this curvature. Participants explore theoretical, conceptual, and observational aspects of GR, including its predictions and the interpretation of mass within this framework.
  • Some participants express confusion about the lack of direct evidence for mass curving spacetime, questioning how GR can be considered a theory without such evidence.
  • Others argue that there is substantial evidence for spacetime curvature, citing phenomena such as the orbit of Mercury, gravitational lensing, and gravitational time dilation as support for GR.
  • A participant suggests that the analogy of spacetime as a "rubber sheet" may be misleading and questions the necessity of a force to curve spacetime.
  • There are discussions about the nature of mass in GR, with some stating that mass is still a measure of inertia and that it influences how spacetime curves.
  • Some participants propose that spacetime curvature may be an analogy for the consequences of mass rather than a literal description of reality.
  • Concerns are raised about applying Newtonian concepts of force and mass to the non-Newtonian framework of GR.
  • Questions are posed regarding the interpretation of light's behavior in curved spacetime and whether it can be explained through classical physics.
Participants do not reach a consensus on the nature of spacetime curvature or the necessity of a force to explain it. Multiple competing views are presented, with some asserting the validity of GR's predictions while others remain skeptical about the interpretation of spacetime and mass.
Some participants highlight the limitations of classical physics in explaining GR concepts, indicating a dependence on definitions and the need for a clearer understanding of mass in the context of spacetime curvature.
This discussion may be useful for individuals interested in the foundational concepts of General Relativity, the nature of spacetime, and the ongoing debates surrounding these topics in physics.
Atran
Hi,
From what I know, science is the study of the observable world, its theories are supported by evidence.
Now GR is a theory, and it informs that mass curves the 'fabric' of space and time. The thing I don't understand is that there is no evidence of mass curving spacetime, then how is GR a theory? If there is evidence, then what is spacetime, really, since it's something which has the potential to be curved?
From what I know, in GR gravity is not a force, it's a curvature of spacetime. If so, force is needed to curve the spacetime, but where is that force in GR?
Thanks...
Atran said:
Hi,
It's like saying you have a theory that the Earth is actually a sphere. Imagine you cannot directly observe this by leaving the earth, and ask what evidence is there for a spherical rather than flat geometry? Surely you can come up with many, but none of them come from the surface itself, but rather its consequences on observable phenomenon. GR is the same. We see einstein's crosses, precession of perihelions, and light being curved all in perfect accord with what we expect if spacetime is curved by mass. The evidence is no less strong.
Thanks...
Why do you assume you need a force to curve spacetime? Simply because a force is required to curve normal objects? Do not take the "rubber sheet" analogy too far! A force is not needed, the presence of mass simply distorts spacetime by the mere fact that it exists.
I am surprised at your ignorance on the subject. There is quite a bit of evidence on the subject, some of it is quite famous such as the orbit of Mercury, gravitational lensing, and gravitational time dilation (along with a lot of less-famous evidence).
Shapiro delay is one of the "orphans". But the most obvious "orphan" is GPS functionality :-)
There is evidence of mass curving spacetime. Of course, it depends somewhat on what you'd consider to be conclusive evidence. It's possible to express GR in a non-geometrical form. In any case, GR is certainly a scientific theory, because it makes a variety of predictions that differ from those of Newtonian gravity, and those predictions have been extensively tested against observations and found to be correct.
I'm in first year of high school (grade 10). My physics book is very classical.
I didn't mean there are no evidence for GR, I meant why to postulate a curved spacetime.
I'm not against SR stuff, I questioned the curvature.
Nabeshin said:
...GR is the same. We see einstein's crosses, precession of perihelions, and light being curved all in perfect accord with what we expect if spacetime is curved by mass...
I mean, is spacetime really curved? or an analogy for the consequences?
This still vague for me. Now in the classical sense, mass is the resistance to change object's state. What is mass in GR?
That would be better for me.
bcrowell said:
...light being curved all in perfect accord with what we expect...
Is that because of photon's momentum and the exerted force by it? I'm not sure...
It depends on what you mean by "really." For example, would you accept the following as evidence? You make a triangle out of three laser beams, and the sum of the interior angles is not equal to 180 degrees. Real experiments very similar to this, although not quite as conceptually simple, have been done. If you want to, you can insist that space isn't "really" curved, and that the beams are curving under the influence og a force or something. But IMO insisting that the beams aren't "really" geometrical lines is unreasonable, since there is nothing that makes a *better* standard of a straight line than a ray of light.
I hope you aren't too taken aback by reactions like DaleSpam's. People here generally don't bite the newbies. It's just that we get a lot of kooks here who think they've proved Einstein is wrong, and people get impatient with them; I think your original post may have given people that impression, when in fact you were just asking an honest question.
There is no need to posit a force that curves spacetime. Force is a concept from Newtonian physics in which one object with mass interacts with another object with mass. Spacetime isn't a material object, so we shouldn't expect a physical force to act *on* spacetime.
Like bcrowell says, you're trying to apply Newtonian reasoning to something decidedly non-Newtonian!
Mass, in GR, is still inertia. Or, a property that determines how much spacetime will curve. The two are the same (note: the equivalence principle). You can still apply forces to things in GR, it's just that gravity is not one of them.
For the photon curving, I would definitely advise you to drop the Newtonian picture of the situation alltogether. Some people like to do a derivation in Newtonian mechanics of this (it gives the wrong result, but only by a factor of 2), but I think it's more destructive than instructive. Simply put, in a curved spacetime anything follows the shortest line between two points (known as a geodesic). Light is no exception, and when the spacetime isn't flat, light does not move in a straight line.
In the Newtonian sense, there are two sorts of masses.
There is inertial mass which is the resistance to change in an object's velocity.
But there is also gravitational mass which produces a gravitational field.
In Newtonian gravity, the gravitational mass is one number at every point in space (the number is zero where there is vacuum). In general relativity, the gravitational mass is 10 numbers at every point in spacetime.
In Newtonian gravity, the gravitational field is a number at every point in space. In general relativity the gravitational field is 10 numbers at every point in spacetime, and these 10 numbers can be interpreted as spacetime curvature by a mathematical analogy.
I mean real, like the screen you're looking at or the chair you're sitting on.
Is it energy or a concept?
I haven't studied more than Newtonian physics yet.
Yea, now I know what the principle means, 'cause I've seen it earlier.
Ok, but I don't know yet more than the classics, I need time.
Ok, thnx.
If gravity is not force and is explained by geometry, then:
How can gravity be written in algebra? What is its unit?
Math can be used for calculating geodesics, but is there a "easy" formula for knowing the deepness/height of an object's curve?
Thanks for all replies.
Let c be the speed of light.
The gravitational field in Newtonian physics is the gravitational potential U, which has units of (speed of light)2, ie. [ U ]=[c2]
The gravitational field in general relativity is the metric tensor g. If coordinate distances have units of metre and coordinate times have units of seconds, then the metric tensor has no units.
[ g ]=[ U ]/[c2]
But I think we can do it the other way round and have coordinate distances and time have no units, and give units to the metric tensor - after all, isn't that supposed to be the thing that gives us length and time? I think it's usually not done that way, because even though length and time should have the same units, we usually use the metre as the unit of length and the second as the unit of time.
http://arxiv.org/abs/astro-ph/0303376
OK, understood. You may want to proof-read your posts more carefully in the future. I hope you can understand how "there is no evidence of mass curving spacetime, then how is GR a theory" sounds exactly like you are asserting that there is no evidence for GR.
In SR an inertially moving object is represented geometrically by a straight line (geodesic) in spacetime and determined experimentally by an ideal accelerometer that reads 0. Two inertial objects at rest wrt each other are represented by parallel lines. In extending these simple concepts to GR you find that gravity can cause two straight lines (accelerometer reads 0) to be parallel at one point (at rest wrt each other) and yet intersect at another point. Two straight lines which are parallel cannot intersect in a flat spacetime, so spacetime must be curved in gravitation.
  • · Replies 58 ·
  • · Replies 29 ·
  • · Replies 52 ·
  • · Replies 21 ·
