What is the ground state wave function of ortho-helium and its degeneracy?
The ground state wave function of orthohelium is defined as u(r1,r2) = (1/√2)[ψ100(r12lm(r2) - ψ100(r22lm(r1)]Xtriplet, where Xtriplet represents the symmetric triplet spin state. This configuration arises because orthohelium has a symmetric spin state, necessitating an antisymmetric spatial wave function. The degeneracy of the ground state is three-fold, attributed to the triplet spin states, as the energy depends solely on the principal quantum number n, with the spatial wave functions being equivalent.
  • Understanding of quantum mechanics, specifically wave functions and quantum states.
  • Familiarity with the principles of antisymmetry and symmetry in multi-particle systems.
  • Knowledge of quantum numbers (n, l, m) and their significance in atomic physics.
  • Basic comprehension of electron spin and its implications for particle statistics.
  • Study the implications of antisymmetry in multi-electron systems in quantum mechanics.
  • Explore the concept of degeneracy in quantum states, particularly in helium and similar systems.
  • Learn about the role of electron-electron interactions in determining wave functions in multi-electron atoms.
  • Investigate the differences between single-electron and multi-electron atom behavior in quantum mechanics.
Physicists, quantum mechanics students, and researchers interested in atomic structure and wave function analysis, particularly those focusing on helium and similar systems.
Oddbio
I want to construct the ground state wave function of orthohelium.
Here is my reasoning, please let me know if I am correct or not.
[EDIT]
I forgot to add that for this post I am ignoring the electron-electron interactions.
[/EDIT]
Orthohelium has the triplet spin state which is symmetric. Because the total wavefunction must be antisymmetric that means that orthohelium must have an antisymmetric spatial wave function to go with the symmetric spin part.
However, I read that the ground state of helium in general MUST have a symmetric spatial wave function. Therefore that cannot also be the ground state of orthohelium.
So we must go to the first excited state, which can be written as:
[tex]u(r1,r2) = \frac{1}{\sqrt{2}}[\psi_{100}(r_{1}) \psi_{2lm}(r_{2}) \pm \psi_{100}(r_{2}) \psi_{2lm}(r_{1})] X[/tex]
where X is the spin wave function. Either singlet or triplet.
the 100 means (n=1 l=0 m=0) which must be true for the electron in the ground state:
the 2lm subscript is (n=2, l=0 or 1, m=-1 or 0 or 1)
Now, because orthohelium must have the X as the triplet spin which is symmetric, then we must use the minus sign in the equation to get the antisymmetric spatial state.
Therefore I get that the ground state wave function of orthohelium is:
[tex]u(r1,r2) = \frac{1}{\sqrt{2}}[\psi_{100}(r_{1}) \psi_{2lm}(r_{2}) - \psi_{100}(r_{2}) \psi_{2lm}(r_{1})] X_{triplet}[/tex]
Then also I am curious as to the degeneracy of the ground state of orthohelium.
IF I am correct, then would I be correct in saying that this ground state of orthohelium it quadruply degenerate?
Because we can have 4 different wave functions for the (l,m) values: (0,0) (1,-1) (1,0) (1,1)
and because the energy only depends on the n quantum number then all four have the same energy right?Any advice will be GREATLY appreciated.
Thanks.
This is correct up to the discussion of degeneracy. Assuming that the energy depends only on ##n##, the result would be 12-fold degenerate, as there are four equivalent spatial wave functions, and three spin states. In reality, the degeneracy of eigenstates of the same ##n## but different ##l## only holds for single-electron (hydrogen) atoms. So the ground state of ortho-helium has ##l=0##, ##m=0##, and is three-fold degenerate due to electron spin.
