| Thread Closed |
Triangular potential Well |
Share Thread | Thread Tools |
| Apr8-10, 07:06 AM | #1 |
Show that the TISE expression you found in part (a): I found it (a) to be: [tex]\frac{d^{2} \psi}{dx^{2}} - \frac{2m}{\hbar ^{2}}(e \xi x - E) \psi (x) = 0[/tex] Show it (a) can be simplified to: [tex]\frac{d^{2} \psi}{dw^{2}} - w \psi = 0[/tex] 2. Relevant equations w = z - z0 where: [tex]z = \left( \frac{2me \xi }{ \hbar ^{2} } \right)^{ \frac{1}{3} } x[/tex] [tex]z_{0} = \frac{2mE}{\hbar ^{2}} \left( \frac{ \hbar ^{2} }{ 2me \xi } \right)^{ \frac{2}{3} } [/tex] 3. The attempt at a solution So far I have found: [tex]w = \left( \frac{2m}{ \hbar ^{2} e^{2} \xi ^{2} } \right)^{ \frac{1}{3} } (e \xi x - E) [/tex] But my problem is: how do I convert: [tex] \frac{d^{2} \psi}{dx^{2}} [/tex] to [tex] \frac{d^{2} \psi}{dw^{2}} [/tex], because I'm totally stuck on that. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Apr8-10, 03:08 PM | #2 |
Well, you know w in terms of x. So what is dw in terms of dx? Then solve for dx^2, and plug it into your Schrodinger Eq.
| Apr8-10, 05:20 PM | #3 |
well,
[tex] dw = \left( \frac{2me \xi }{ \hbar ^{2} } \right)^{ \frac{1}{3} } dx[/tex] [tex] \therefore dw = z dx [/tex] But I'm confused as to how thats going to help. |
| Apr8-10, 05:21 PM | #4 |
Mentor
Triangular potential Well[tex]\frac{df}{dx} = \frac{dw}{dx}\frac{df}{dw}[/tex] |
| Apr8-10, 05:25 PM | #5 |
[tex]\frac{d^2 \psi}{dx^2}[/tex] with that and get the 2nd derivative in terms of w. Then you will want to divide out the factor in front of your new 2nd derivative to get the 2nd equation you listed in your first post. EDIT: The chain rule will also get you the same thing. But since w is linearly proportional to x, I just take the proportionality constant out and square it. EDIT2: Also, the cube roots look right. They are needed to cancel out all the coefficients in the final form of the equation. If QuantumJG finishes this last step, then he should get a simple ODE in terms of w only and no other terms. |
| Apr8-10, 05:37 PM | #6 |
[tex] \frac{d}{dx} \left( \frac{df}{dx} \right) = \frac{d}{dx} \left( \frac{dw}{dx}\frac{df}{dw} \right) [/tex] [tex] = \frac{df}{dw} \frac{d}{dx} \left( \frac{dw}{dx} \right) + \frac{dw}{dx} \frac{d}{dx} \left( \frac{df}{dw} \right) [/tex] |
| Apr8-10, 05:39 PM | #7 |
Use the chain rule on the last term:
[tex]\frac{dw}{dx}\frac{dw}{dx}\frac{d}{dw}\left(\frac{df}{dw}\right)[/tex] |
| Apr8-10, 05:47 PM | #8 |
| Apr8-10, 05:51 PM | #9 |
Mentor
| Apr8-10, 05:56 PM | #10 |
Mentor
[tex]\left(\frac{d}{dx}\right)^2 = \frac{dw}{dx} \frac{d}{dw}\left(\frac{dw}{dx} \frac{d}{dw}\right) = \left(\frac{dw}{dx}\right)^2 \frac{d^2}{dw^2}[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Triangular potential Well
| Re triangular numbers | Linear & Abstract Algebra | 2 | ||
| Triangular matrices | Linear & Abstract Algebra | 1 | ||
| Triangular Whatchamacallum | Introductory Physics Homework | 1 | ||
| Triangular obelisk | Differential Geometry | 2 | ||
| Sum of Two Triangular Numbers | Calculus & Beyond Homework | 2 | ||
