| New Reply |
Integral of squared error function |
Share Thread | Thread Tools |
| Apr9-10, 06:59 AM | #1 |
Does anybody knows how to solve the following equation?
[tex]\int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx[/tex] Please help. regards singhofmpl |
| Apr9-10, 07:25 AM | #2 |
Recognitions:
Policy is that you must show us working before we can provide substantial help. If we don't know what you have done we done know where you got stuck. The hints I'll give you this time are: Trying integrating by parts to reduce the exponent of the error function in the integral. You can find the derivative of the error function by the Fundamental Theorem of Calculus.
| Apr9-10, 07:50 AM | #3 |
Your suggestion is very much correct as far as applying by parts is concerned but I'm able to get analytical results only if the integral involves only one power of the error function i.e [tex]\int_{0}^{\infty}\mbox{erf}(\sqrt{x})\exp(-x)dx[/tex] but I'm not able to get the correcr results for the integral [tex]\int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx[/tex]. If I apply by parts to the integral involving squared error function then after a long derivation finally I'm getting 0, which I' m suspicious that this solution is correct. |
| Apr9-10, 08:11 AM | #4 |
Recognitions:
The answer is not zero as the integrand is strictly positive on the interval of integration. Please show me the steps you did. From the start: To reduce the power of [tex]Erf^2\sqrt{x} [/tex] in your integral, use integration by parts, letting [tex]u= \Erf^2 \sqrt{x}, dv = e^{-x} dx[/tex]. To find du, use the definition of the Error function and the Fundamental Theorem of Calculus.
After you carry that out, you should have an integral like : [tex]\int^{\infty}_0 Erf (\sqrt{x}) e^{-2x} dx[/tex] So exp (-2x), not just exp (-x). You can't finish there. You have to apply integration by parts again in a similar fashion, then continue from there. |
| Apr9-10, 09:20 AM | #5 |
Respected Sir
I'm sorry to say bet still there is problem. Please see my workings given below: [tex]\int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx[/tex] let [tex]u=\mbox{erf}^2(\sqrt{x})[/tex] Now [tex]du=\frac{2\mbox{erf}(\sqrt{x})\exp(-x)}{\sqrt{\pi}\sqrt{x}}dx[/tex] Now it is required to write [tex]\exp(-x)dx[/tex] in terms of [tex]du[/tex]. So [tex]\exp(-x)dx=\frac{\sqrt{\pi}\sqrt{x}}{2\mbox{erf}(\sqrt{x})}du[/tex] which further can be written as: [tex]\exp(-x)dx=\frac{\sqrt{\pi}\sqrt{x}}{2\sqrt{u}}du[/tex] but the problem is how to write [tex]\sqrt{x}[/tex] in terms of u? Please help |
| Apr9-10, 09:29 AM | #6 |
Recognitions:
No, you are doing a plain u substitution. I said integration by parts! Have you seen integration by parts before?
[tex]\int u dv = uv - \int v du[/tex] http://en.wikipedia.org/wiki/Integration_by_parts |
| Apr9-10, 10:47 AM | #7 |
Dear Sir
Thanks a lot for your prompt response. I'm really very sorry for bothering you so much. Finally I got the solution following your advice. The final answer which I'm getting is given below: [tex]\frac{2\sqrt{2}\arctan(\frac{1}{\sqrt{2}})}{\pi}[/tex] Please let me know whether my answer is correct. |
| Apr9-10, 11:02 AM | #8 |
Recognitions:
That is correct. Don't worry about asking questions, It wasn't a bother at all.
| Apr9-10, 11:06 AM | #9 |
Dear Sir
May I know your affiliation (if you don't mind) so that I can mention it while writing my report or paper? |
| Apr9-10, 11:09 AM | #10 |
Recognitions:
My name is Ragib Zaman, and I am a first year student at the University of Sydney, Australia. I am studying the Bachelor of Science (Advanced Mathematics) degree.
| Jun6-10, 07:39 AM | #11 |
Hi Ragib
While modeling the non-linear behavior of power amplifier (PA), I came to an integral of the form given below; I'm not able to figure out how to solve it. [tex]I=\frac{A^2}{2\sigma_x^4}\int_{0}^{\infty}\frac{r^3}{r^2+A^2}\exp(\frac {j\pi}{3}\frac{r^2}{r^2+A^2}-\frac{r^2}{2\sigma_x^2})dr[/tex] Please help me to solve it analytically. |
| Jun6-10, 08:44 AM | #12 |
Recognitions:
After some initial manipulations I've managed to make it look like
[tex]ke^k \int^{\infty}_k \left(1-\frac{k}{t}\right) \frac{e^{\frac{i\pi}{3}\left(1-\frac{k}{t}\right)}}{e^t} dt[/tex] where [tex] k = \frac{A^2}{2\sigma_x^2}[/tex] I'm still working on reducing that further, but in the mean time you could give that form a try. |
| Jul9-10, 04:26 AM | #13 |
Dear Sir
kindly suggest me how find the integration of : [tex]\int_{0}^{\infty}\mbox{erf}(\sqrt{x})\exp(-x)dx[/tex] |
| Oct31-10, 11:04 AM | #14 |
Hi, may I know how do you solve for [tex] \int_{0}^{\infty}\mbox{erf}(\sqrt{x})\exp(-x)dx [/tex]?
Could you detail the assignment of 'u' in each iteration of integration, and how do you get the eventual term in arctan? Could you give me some hints on solving that because it seems to me that the integrations would loop infinitely. I dearly need your advice. Thanks. |
| Oct31-10, 12:06 PM | #15 |
Recognitions:
It's not very hard, I'm certain you can do it if you try. Integration by parts with [itex] u = erf( \sqrt{x} ), dv = e^{-x} dx [/itex]. To find du, use the fundamental theorem of calculus and the chain rule.
| Nov1-10, 02:43 AM | #16 |
Regarding the original problem:
[tex] \int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx [/tex] here is what I've got so far. [tex] u=\mbox{erf}^2(\sqrt{x}), [/tex] [tex] du=\frac{2\mbox{erf}(\sqrt{x})\exp(-x)}{\sqrt{\pi}\sqrt{x}}dx, [/tex] [tex] dv = \exp(-x) dx, [/tex] [tex] v=-\exp(-x). [/tex] Thus, we have [tex] \int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx = -\exp(-x)\mbox{erf}^2(\sqrt{x}) + \int_{0}^{\infty}\frac{2\mbox{erf}(\sqrt{x})\exp(-2x)}{\sqrt{\pi}\sqrt{x}}dx. [/tex] Now suppose that I do another integration by parts with [tex] u=\mbox{erf}(\sqrt{x}), [/tex] [tex] du=\frac{\exp(-x)}{\sqrt{\pi}\sqrt{x}}dx, [/tex] [tex] dv = \frac{\exp(-2x)}{\sqrt{x}} dx, [/tex] [tex] v=\frac{\sqrt{\pi}\mbox{erf}(\sqrt{2x})}{\sqrt{2}}. [/tex] The resultant expression becomes [tex] \int_{0}^{\infty}\mbox{erf}^2(\sqrt{x})\exp(-x)dx = -\exp(-x)\mbox{erf}^2(\sqrt{x}) + \sqrt{2}\mbox{erf}(\sqrt{x})\mbox{erf}(\sqrt{2x}) - \frac{2\sqrt{2}}{\sqrt{\pi}}\int_{0}^{\infty}\frac{\mbox{erf}(\sqrt{2x} )\exp(-x)}{\sqrt{x}}dx. [/tex] and I'm stuck at this point where the form of [tex]\frac{\exp(x)\mbox{erf}(x)}{x}[/tex] in the integration cannot be suppressed. I have tried to proceed with another round of integration and a similar form returns. Please kindly point me out my mistake(s). Thanks. |
| Nov17-10, 04:31 AM | #17 |
Recognitions:
Here you go meng: [tex] I = \int^{\infty}_0 \mbox{erf}(\sqrt{x}) e^{-x} dx [/tex] Integrate by parts, letting [itex] u = \mbox{erf} \sqrt{x} , du = \frac{1}{2\sqrt{x}} \cdot \frac{2}{\sqrt{\pi}} e^{-x} dx [/itex] and [itex] dv = e^{-x} dx, v = - e^{-x} [/itex], where we found the derivative of u by the fundamental theorem of calculus. This gives: [tex] I = \left[ -\mbox{erf}\sqrt{x} e^{-x} \right]^{\infty}_0 + \int^{\infty}_0 \frac{ e^{-2x} }{ \sqrt{\pi x} } dx [/tex]. For the 1st term, as x goes to infinity, the erf term goes to a constant since [itex] \int^{\infty}_0 e^{-x^2} dx = \sqrt{\pi}/2 [/itex] while the exp goes to zero, so thats zero. And when x=0, the erf term is 0 while the exp term is 1, so zero as well. So we just have the integral remaining, in which we let [itex] u = \sqrt{x} [/itex] which leaves us with [tex] I = \frac{2}{\sqrt{\pi}} \int^{\infty}_0 e^{-2u^2} du [/tex]. Let [itex] t = \sqrt{2} u [/itex], [tex] I = \frac{ \sqrt{2}}{\sqrt{\pi}} \int^{\infty}_0 e^{-t^2} dt = \frac{1}{\sqrt{2}} [/tex] |
| New Reply |
| Thread Tools | |
Similar Threads for: Integral of squared error function
| Integral of squared error function | Calculus | 0 | ||
| Question about Mean Squared Error::Why Squared? | Set Theory, Logic, Probability, Statistics | 10 | ||
| integral of force squared | Classical Physics | 2 | ||
| error function integral | Calculus | 3 | ||
| Error Function & Imaginary Error Function - Formulas | Set Theory, Logic, Probability, Statistics | 0 | ||
