Violating the principle of relativity
The discussion revolves around the apparent contradiction in the application of the principle of relativity to electromagnetic interactions, particularly focusing on the behavior of protons moving relative to each other and the resulting forces they experience. Participants explore the implications of reference frames on electric and magnetic fields, and the transition from electrostatics to electrodynamics.
  • One participant, mr. vodka, presents a scenario involving two protons moving towards each other and questions how the magnetic field perceived in one frame appears as an electrostatic force in another frame, suggesting a contradiction.
  • Another participant argues that there is no contradiction, asserting that the magnetic effects in one frame correspond to electrostatic forces in another frame.
  • Concerns are raised about the validity of Coulomb's law when charges are in motion, with participants discussing the need to consider the propagation speed of electric fields in electrodynamics.
  • Participants express surprise at the implications of moving charges on the application of Coulomb's law, questioning whether it is universally applicable in all reference frames.
  • One participant provides a mathematical expression for the electric field of a moving charge, indicating that traditional electrostatic methods may not apply when dealing with time-dependent situations.
Participants do not reach a consensus; there are competing views on the application of Coulomb's law in the presence of moving charges and the interpretation of electromagnetic forces across different reference frames.
Limitations include the unresolved nature of how electric fields behave in dynamic situations and the dependence on the definitions of electrostatic versus electrodynamic forces. The discussion highlights the complexities introduced by the finite speed of electromagnetic field propagation.
nonequilibrium
It seems really basic, like a remark which probably everyone asks himself when first coming upon electromagnetism, but I can't see the error in my reasoning, which leads to violating the principle of relativity:
Imagine two protons passing each other by, each with a speed v, opposite to each other, but one is flying just higher so that they don't collide. As the bottom one passes beneath the top one and they're at their closest point, the bottom one is creating a magnetic field that is pushing the top one away (well, the resulting Lorentz force is, anyway). (note: there is also an electric force)
Now imagine the same experiment, but viewed from an inertial reference frame with a speed v flying in the direction of the bottom proton. Now, as they pass at the same point, the bottom proton is not creating a magnetic field because in this reference frame it is standing still. So there is no magnetic force pushing the top one away, only the electric force, which hasn't changed.
Contradiction.
Much obliged,
mr. vodka
No contradiction. All you have discovered is that what looks like magnetism in one frame looks like the electrostatic force in another.
That sounds interesting... but sadly I don't understand? The formula for the electrostatic ("static"?) force is kqQ/r², which is identical in both cases...
And you've hit on the other piece!
That formula is only valid for electrostatics!
In electrodynamics, you need to take into account that changes in the electric field only propagate at the speed of light.
This is where you are mistaken. Here is an applet which let's you play with the E-field of a moving charge. The velocity bar is given as a c fraction.
http://www.its.caltech.edu/~phys1/java/phys1/MovingCharge/MovingCharge.html
Wow! The formula changes for moving charges? Bombshell. Where does this come from? I just saw Maxwell laws in my first year of university (the integral-forms). Out of which one does this follow? I must say I hadn't expected this. So all those times I've used Coulomb's law for charges with v not zero, I was doing something wrong? It's too hard to believe...
EDIT: but weren't there like at least 100 years between this part of physics and the discovery of the theory of relativity? How did they solve this obvious problem?
What do you mean? Relativity theory is founded on the predictions of Maxwell's Equations and the Principle of Relativity. Relativity assumes the predictions of maxwell are correct.
The E-field of the moving charge is given here by Dalespam (The correct expression is the one on the bottom.):
https://www.physicsforums.com/showpost.php?p=2625933&postcount=40
Interesting formula. (and hefty)
And ah, I thought the formula that gave the correct electrodynamic forces was derived from special relativity, my bad. Don't know why I assumed that.
But does this mean EVERY situation where you're in a reference frame that has moving charges, Coulomb's law is simply wrong? I'm flabbergasted. Was the above situation just an exception?
It's really not as bad as you think. The electric field can be written as, assuming no magnetic field:
[tex] E(\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}} <br /> \over x} ) = \frac{1}{{4\pi \varepsilon _o }}\int {\frac{{\rho dV'\hat r'}}{{|\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}} <br /> \over x} - \mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}} <br /> \over x} '|}}}[/tex]
as you would expect. However, what if [tex]{|\mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}} <br /> \over x} - \mathord{\buildrel{\lower3pt\hbox{$\scriptscriptstyle\rightharpoonup$}} <br /> \over x} '|}[/tex] is time dependent? All of your methods for solving electrostatics falls apart. If you had a charged particle flying away from you, the magnitude of the distance is changing. To add to that, it's not an instantaneous change either! Since the speed of e/m fields is finite, movement in the source won't translate into an instantaneous change in the field at the observation point.
  • · Replies 33 ·
  • · Replies 144 ·
10K
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 35 ·
