How Much Power is Needed to Drag a Table Across a Brick Floor?
  • Thread starter Thread starter dgomez89
    Power
The discussion revolves around calculating the power required to drag a 20.0 kg table across a brick floor, focusing on the effects of friction and the relationship between force, distance, and time. The problem involves concepts from mechanics, particularly relating to forces and power in a frictional context.
  • The original poster attempts to apply equations related to power and friction but expresses uncertainty about their approach. Some participants clarify the need to focus on overcoming friction rather than gravity and suggest different methods for calculating power, including finding work first or calculating speed.
Participants are actively exploring different interpretations of the problem and discussing the necessary steps to find the solution. Guidance has been offered regarding the importance of calculating the force exerted and the relationship between work and power.
There is a mention of the coefficient of kinetic friction and the need to consider the normal force in the context of the problem. The original poster expresses confusion about their calculations and seeks further assistance.
dgomez89
How much power must you exert to horizontally drag a 20.0 kg table 14.0 m across a brick floor in 40.0 s at constant velocity, assuming the coefficient of kinetic friction between the table and floor is 0.600?
P=F(d/t), fk=mukN
P=(20.0*9.8)(14.0/40.0) fk=(0.600*20.0*9.8)
=68.6W =117.6
117.6-68.6=49W
I really do not know how to do this problem, I just tried it in a way that made some sense to me, but it's obviously wrong. PLEASE HELP!
When you drag something horizontally, you must do work to overcome the force of friction, not gravity.
your first equation P = F (d/t) tells you the power needed to push something with a force F, that's moving in the direction of that force with a constant speed v = d/t
The second equation [itex]F_k = \mu_k N[/itex] tells you how big the friction is if you know the normal force N
So then do i need to find the work first and then whatever value I get from that use it to find the Power by using P=W/t?
You can do that, or calculate the speed first and then Power = force * speed.
The equation you gave P = F (d/t) does this all at once.
The important thing is to calculate the force you must exert first.
