Thermodynamics: Determine Temp State B (K) at 7atm, 634°C
  • Thread starter Thread starter Dakaa
    Thermodynamics
The discussion focuses on determining the temperature of an ideal monoatomic gas at state B during a thermodynamic process involving isothermal expansion, isobaric compression, and isochoric heating. Given that the gas undergoes an isothermal expansion from state A to state B, the pressure at state C is 7 atm and the temperature is 634 °C. Using the ideal gas law and the relationships between states, the temperature at state B can be calculated using the formula T_B = (P_C * V_B) / (n * R), where R is the molar gas constant (8.314 J mol–1 K–1).
  • Understanding of the ideal gas law
  • Knowledge of thermodynamic processes: isothermal, isobaric, and isochoric
  • Familiarity with the concepts of pressure and temperature conversions
  • Basic proficiency in using the molar gas constant (R) and Boltzmann's constant
  • Calculate the temperature at state B using the ideal gas law
  • Explore the relationships between different thermodynamic states
  • Learn about the implications of isothermal and isobaric processes on gas behavior
  • Investigate the application of the first law of thermodynamics in gas transformations
Students and professionals in physics and engineering, particularly those studying thermodynamics, gas laws, and related applications in mechanical and chemical engineering.
Dakaa
Two moles of an ideal monoatomic gas doubles its initial volume in an isothermal expansion from state A to state B. The gas is then compressed isobarically to state C and finally heated isochorically until it returns to state A. The molar gas constant is R = 8.314 J mol–1 K–1 and Boltzmann's constant is 1.38 × 10–23 J K–1.
(a) If state C corresponds to a pressure P = 7 atm (1 atm = 1.013 × 105 Pa) and temperature T = 634 °C, determine the temperature of the gas in state B in K.
You will need to show some work so we can guide you in the right direction. For a start, you could write out the equations that relate A to B, B to C, and C to A.
9K
