Thread Closed
Refractive index
Share Thread Thread Tools
Apr13-10, 06:58 PM   #1
Refractive index
Maxwell theory
[tex]n=\sqrt{\epsilon_r \mu_r[/tex]
Refractive index for water is [tex]n=1,33[/tex]. For water [tex]\epsilon_r=81, \mu_r=1[/tex] so it should be
[tex]n=9[/tex]
Why we have so big anomaly for water?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Apr13-10, 09:21 PM   #2
Recognitions:
Quote by Petar Mali View Post
Maxwell theory
[tex]n=9[/tex]
The index of refraction and the reduced electric permittivity are both frequency dependent quantities, they are not constants. The constant value of 81 you refer to is the reduced electric permittivity of room temperature water in the limit that the frequency goes to zero. A frequency of zero is clearly a bad approximation for the optical frequencies where index of refraction is typically measured.
My guess is that the index of refraction of water for very low frequency radiation probably *is* around 9 ... that is probably part of the reason why radio waves cannot penetrate the water very effectively, whereas shorter wavelength visible light penetrates much further.
Thread Closed
Thread Tools
Similar Threads for: Refractive index
Thread Forum Replies
Refractive Index General Physics 0
Refractive index of gold? (& negative refractive index, + surface plasmon resonance?) Atomic, Solid State, Comp. Physics 3
Refractive index Classical Physics 11
?? Refractive Index ?? Materials & Chemical Engineering 3
Refractive index General Physics 3
