Understanding Welding Polarity: Tips for Using a Mig/Flux Welder
  • Thread starter Thread starter GENIERE
    Polarity Welding
This discussion focuses on the importance of welding polarity when using a MIG/flux welder. When using solid welding wire with gas, the wire connects to the positive terminal, while the workpiece connects to the negative terminal. In contrast, with flux core wire, the polarity must be reversed to achieve optimal welding results. Incorrect polarity can hinder the ability to create a good bead, as the heat concentration and weld penetration are significantly affected by the electrode's charge.
  • Understanding of MIG/flux welding techniques
  • Familiarity with welding polarity concepts
  • Knowledge of gas vs. flux core welding wire
  • Basic principles of heat concentration in welding
  • Research the effects of welding polarity on weld penetration
  • Learn about the differences between solid wire and flux core wire in MIG welding
  • Explore the principles of heat distribution in welding processes
  • Study the impact of electrode charge in gas tungsten arc welding
This discussion is beneficial for hobbyist welders, welding students, and professionals seeking to enhance their understanding of MIG/flux welding techniques and the critical role of polarity in achieving quality welds.
GENIERE
I have time on my hands these days so I bought a Mig/flux welder. I have no idea what I’ll do with it but I always wanted one. The machine allows welding with wire that has a flux core or with a gas “shield. Presumably the gas or flux prevents oxidation of the metal when heated.
The question I have is that when gas is used with solid (no flux core) welding wire you are directed to connect the wire to the positive terminal and the material to be welded is connected to the negative terminal. When using flux core (no gas) wire you must reverse the polarity. I haven’t used gas but incorrect polarity with the flux wire makes it much harder to get a good bead started. I can’t think of a good reason why the polarity would matter. Anyone have a thought?
Changing polarity has several effects.
From Wikipedia:
In welding, the positively charged anodewill have a greater heat concentration, and as a result, changing the polarity of the electrode affects weld properties. If the electrode is positively charged, the base metal will be hotter, increasing weld penetration and welding speed. Alternatively, a negatively charged electrode results in more shallow welds.[30] Nonconsumable electrode processes, such as gas tungsten arc welding, can use either type of direct current, as well as alternating current. However, with direct current, because the electrode only creates the arc and does not provide filler material, a positively charged electrode causes shallow welds, while a negatively charged electrode makes deeper welds.
  • · Replies 37 ·
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 43 ·
12K
