Thread Closed
Intensity of light with given power through a polarizer
Share Thread Thread Tools
Apr14-10, 10:28 PM   #1
1. A 200 mW horizontally polarized laser beam passes through a polarizing filter whose axis is 25 degrees from vertical.
2. Malus's Law
3. Ok, so I will use theta = 65 degrees in the I = I0cos(theta) equation, right? But how do I calculate I0 knowing only power and not area?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Apr15-10, 12:29 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
How is the intensity of light defined? And what does Malus's Law say? The equation you use is wrong.
ehild
Apr15-10, 08:03 PM   #3
I = P/A = 0.5c*ep0*E2
And Malus's law states that the intensity of the light transmitted is the product of the intensity of the incident light and the square of the cosine of the angle theta with respect to the polarizer's axis. I don't get what you're getting at....
In terms of the theta I use, this is how I am thinking about it: I would use 25 degrees if the incident light was vertically polarized. Since it is horizontally polarized, i.e. is at 90 degrees, I should use 90-25 = 65 degrees...
Apr15-10, 11:41 PM   #4
Recognitions:
It is all right if you use the square of the cosine, but you wrote I=Io*cos(theta) in the previous post.
As for intensity, it is power/area. The incident power of the laser beam is given and the area is the same before and after crossing the polarizer. You did not write what is the question, but presumably it is the power of the laser beam after the polarizer.
ehild
Thread Closed
Thread Tools
Similar Threads for: Intensity of light with given power through a polarizer
Thread Forum Replies
Intensity and Power Introductory Physics Homework 4
Need help to gradually ramp up/down intensity of LED at power-on/power-off Electrical Engineering 2
Why does light intensity decrease when light passes through a glass block? General Physics 7
Intensity of light / measuring wavelength of light Introductory Physics Homework 2
Circularly polarized light through a linear polarizer Advanced Physics Homework 9
