Intensity of unpolarized light through two polarizers
  • Thread starter Thread starter Linus Pauling
    Intensity Light
The discussion centers on the intensity of unpolarized light passing through two polarizers, specifically using Malus's Law. An initial intensity of 440 W/m² is reduced to 220 W/m² after the first polarizer, which is vertical. The intensity after the second polarizer, positioned at 20 degrees from vertical, is calculated incorrectly as 207 W/m². The correct approach emphasizes understanding the relationship between the electric field and intensity, focusing on ratios rather than absolute values.
  • Understanding of Malus's Law
  • Knowledge of electric field concepts
  • Familiarity with intensity calculations in optics
  • Basic principles of polarization
  • Study the derivation and applications of Malus's Law
  • Explore the relationship between electric field strength and intensity in electromagnetic waves
  • Learn about the effects of multiple polarizers on light intensity
  • Investigate practical applications of polarization in optical devices
Physics students, optical engineers, and anyone interested in the principles of light polarization and intensity calculations.
Linus Pauling
1. Unpolarized light with intensity 440 W/m2 passes first through a polarizing filter with its axis vertical, then through a polarizing filter with its axis 20.0 degrees from vertical.
2. Malus's Law
3. Ok, the intensity after going through the first polarizer should be 1/2 the original. This, after the second polarizer, I = 220*cos20) = 207 W/m2, which is incorrect.
The filter works by allowing only the parallel component of the electric field, E cos(theta), through. How are the electric field of the light and the intensity of the light related?
I = P/A = 0.5c*epsilon_0*E^2
Again, I don't see how to get I from P without knowing A.
You're getting too caught up in just brute force calculation when you should be focusing on how one quantity depends on another. You don't need to know P or A. Think ratios.
  • · Replies 25 ·
10K
