Being shot by a bullet in space. Damaging? Why/why not?
  • Context: Undergrad
  • Thread starter Thread starter rflxion
    Bullet Space
The discussion revolves around the effects of being shot by a bullet in space, specifically whether a target would sustain damage from a bullet fired in a vacuum. Participants explore the implications of conservation of momentum, the nature of bullet impacts, and the mechanics of energy transfer during such an event.
  • Some participants argue that a bullet fired in space would still cause damage, as the gunpowder contains its own oxidizer, allowing the gun to fire despite the lack of oxygen.
  • Others propose that the conservation of momentum means that the target would be pushed in the same direction as the bullet, potentially leading to minimal damage if the bullet does not penetrate.
  • It is suggested that if the bullet does not fully penetrate, the momentum transfer could still result in tissue damage due to the energy involved in the impact.
  • Some participants emphasize the importance of considering both momentum and energy conservation, noting that kinetic energy lost during the impact would convert to deformation energy and heat, contributing to damage.
  • One participant highlights that for the target to avoid damage, it would need to be moving at the same speed as the bullet or the bullet would need to stop before impact, which is unlikely in the given scenario.
  • Another point raised is that the bullet's impact would not result in the dramatic effects often portrayed in films, as real-life physics would dictate a more subdued reaction.
  • Some participants discuss historical contexts of bullet effectiveness, noting that larger caliber bullets were designed to deliver more stopping power, but the reasons for this effectiveness remain debated.
  • Calculations presented by a participant suggest that the momentum transfer would result in a small change in velocity for the target, indicating that while they may be slowed down, they would still sustain injuries from the impact.
Participants generally disagree on the extent of damage caused by a bullet fired in space, with multiple competing views on the mechanics of the impact and the implications of momentum and energy conservation. The discussion remains unresolved regarding the specifics of damage and the effectiveness of bullets in such a scenario.
Some assumptions about the mechanics of bullet impacts and the conditions in space are not fully explored, including the role of external forces and the nature of inelastic collisions. The discussion also touches on historical anecdotes without reaching a consensus on their relevance to the current topic.
rflxion
Hi guys,
Just a simple question about space and bullets. I realize this topic comes up a lot, but specifically the only answer I can find is that of the shooter moving back with an equal and opposite force to the bullet, by the conservation of momentum.
Rather, (and ignoring for a moment the fact that the gun wouldn't fire due to the lack of oxygen) IF you were to fire a gun from space, at another person also in space, would the target get hurt/damaged?
Myself and a friend were having this debate, and to me it seems as though the net result would be the target being moved in the same direction as the bullet, but overall coming away unscathed because of the absence of any external opposing forces.
Is there something obvious I'm missing here, or would that, in fact, be the case?
Astronomy news on Phys.org
rflxion said:
Hi guys,
First, I believe the gun will fire in space. The round does not use O2 from outside the casing.
Second, Force and Momentum are different things. You are correct that momentum is conserved. Do you know the definition of momentum, in terms of mass and velocity? You can find it on wikipedia.org or other similar websites.
Using the momentum equation, and the fact that the total momentum of the bullet and the target person will be the same before and after impact, calculate the final velocity of the combined person+bullet. Does that tell you something about the damage?
yes, the gun will fire in space because gunpowder contains its own oxidizer, and yes it will still damage the target. If the bullet does not penetrate all the way through the target all of the momentum will be transferred, but this transfer will still damage tissues.
the best comparison to this is meteorite collisions with earth. as we know these do a large amount of damage to the planets surface.
When doing these kinds of problems you need to consider conservation of momentum and energy. Momentum will be conserved. This may result in a change of kinetic energy, all of the kinetic energy that was lost will go into deformation energy and heat, which is what causes the damage. So the damage is related to the change in kinetic energy.
It might also help to intuitively consider in what manner would the unlucky target avoid damage. Only if the bullet fully stopped (before impact) or if the target were moving equal to or quicker than the bullet could this occur.
Now consider that the target is originally stationary, while the bullet is zipping through space without air resistance, and then consider how, if at all, the above two non-damaging scenarios are possible.
The force multiplied by the time it is acting is called the Impulse. The impulse is the amount by which the momentum of the bullet and victim changes (same amount of force - just opposite direction- and same length of time for each). This means the bullet's loss in momentum is the same as the victim's gain in momentum.
The same velocity change will be experienced, in fact, by the victim as that of the person who fired the shot (assuming they are both of similar mass and both are 'detatched'.
But this is an inelastic collision; Kinetic Energy is not conserved. The final velocity of the victim (plus embedded bullet) will be a very small fraction of the bullet's initial velocity. The Kinetic Energy of the combination will be a lot less than the KE of the bullet so the balance of the Energy will have been transferred into damage to the victim. It will make very little difference whether the victim is in space or standing on the ground. Most of the damage will have been done before the victim has reached his final velocity. It's not like they show in the films, where people get knocked over by bullets!
Minor point, but people get "knocked over" by bullets in real life too. It's called stopping power, and many different firearms were developed with that in mind. Back in the day, an 0.50 inch musket ball would certainly knock you over, and the 0.45 caliber pistols were initially developed to knock over tribal warriors in the Phillipines during the Moro rebellion. They would get all hopped up on stimulants, wrap themselves in thick hempen rope, and attack the US soldiers by running at them with machetes. The 0.38 caliber side-arms of the time simply didn't deliver enough impulse to knock them over when they struck the rope, and they would shrug off any indirect hits, get in close, and hack the soldiers up with machetes. The 0.45 caliber rounds delivered enough stopping power to knock them over, and (much like the kid brother in "A Christmas Story") they couldn't get up easily because they were wrapped up in rope.
I did some simple sums, using momentum conservation.
Assume, first, that it happens in space. If a 80kg body is hit by a 0.2 kg 45 bullet (about the largest used), traveling at 300m/s and the bullet doesn't travel through the body, the two will move off at 0.6m/s or 1.6mph. This would be the speed change of a warrior, running at at least 2m/s. It would 'slow him down' but not 'stop' him, in the simple mechanical sense. He would feel a bit unwell after the impact and probably fall down, of course, due to his injuries. The rope must have acted as a very effective padding against the 38 rounds but was not sufficient to deal with the 45 shots. The fact that the 45 rounds worked does not constitute an explanation of why.
The same thing applies to the guy firing the gun - if the 'recoil' momentum (which you can't eliminate except by anchoring yourself to the ground) were any more, the gun would not be usable. This would be a real problem with continuous fire!
The Cinema shots of people being thrown backwards are just not real. I saw a sequence on some trashy Science TV prog in which they hung a pig(?) carcass on a rope and fired various guns at it. The result was never more than a small movement backwards. That was reality - not a special effect.
no spectra bullets will not knock you over. when they said the .45 could knock over tribal warriors they just meant that it killed them very quickly. because of Newtons 3rd law if they person being shot is knocked back the person firing the gun will be sent back an equal distance.
Please note here that I am not saying Hollywood gets it right ... I was only saying that bullet impacts could knock over a human in real life as well. I believe this is more a question of imparting torque to a person's body who is standing/running on solid ground in a gravitational field (and thus not so applicable to the OP's question). I do agree that a bullet could not lift a person off their feet and propel them through a wall, as is sometimes shown in the movies.
However, it looks like I will have to do some calculations of my own ... I am sure the historical anecdotes are accurate, but sophiecentaur is correct, I don't really know why the .45 was more effective. Perhaps it just caused the warriors to be knocked off balance and fell down. I will also look up the historical references with regards to large caliber musket balls, I have definitely seen eyewitness accounts from revolutionary war era soldiers who recounted their comrades being knocked off their feet by bullet impacts.
One thing I can perhaps shed some light on is the issue of why recoil doesn't knock the shooter backwards. Several factors contribute to the physics there. First, the chamber gases are vented, allowing much of the recoil force to be directed along vectors normal to the bullet flight path. Second, the shooter usually has a firm stance and is expecting the recoil, allowing them to direct the recoil force upwards in a (hopefully) controlled manner.
Whatever you do with gases, you cannot change the Momentum situation due to the bullet. One thing you can do is to make sure that the force on the shooter is spread over as long a time as possible -so it can be less for the same value of impulse. Some resilience between the barrel and your shoulder can achieve this.
There will be a finite amount of momentum in the emerging gases. If they can be directed sideways (equal and opposite) instead of forwards then there is less momentum imparted to the shooter.
actually in a handgun the majority of the gasses are vented forward, which does nothing to reduce recoil, there are no handguns in which the gases go anywhere but forwards. in some rifles gases are vented to the sides in what is called a flash guard, this is to keep the muzzle flash from temporarily blinding the shooter, and has little effect on recoil.
The only gun that could possibly knock someone over is the .50 cal rifle, which fires an 800 grain bullet at 2900fps with force of 14,895 ft lbs(20195 J).
"force of 14,895 ft lbs(20195 J). "
That would be the Kinetic Energy, not force.
I can't be naffed to work out what those other units mean. I only speak SI, as a rule.
Just to point out, many modern guns rely on gravity in some form or another to reload or eject a cartridge, so there would have to be compensation for that or the gun would jam after only one or two shots
You mean you can't shoot whilst you're laying on your back? That seems a bit of a limitation.
Going back to the original post, in this collision the bullet may enter the 80kg body and travel with it or just pass through it. In this case the kinetic energy of the bullet is being applied to a very small area on the human body, specifically its tip. The pressure is applied to the skin and organs and it does not change because it is happening in a vacuum, laws of Physics are the same everywhere. If you thought of them bouncing away in opposite directions, or the bullet dragging the person without any damage also consider that the bullet has a mass which is a whole lot less than the human being but most of its energy is due its speed not it's mass. At the 1/2mv^2 we can see kinetic energy depends more on speed than mass however the effect it applies depends on the surface area that the force is being applied to, which in this case is less than 0.1mm^2 (tip of the bullet, I am not sure of the exact size, but it is pretty small.) If what you said was correct a sharp knife wouldn't cut anything that is not being held in space by an external force. And you would be right if you tried it using a kitchen knife and a leaf of lettuce. However if you took a sharp knife and wield it against a water melon floating in space with enough velocity, you just committed to the murder of a melon. :)
I can't think of any modern firearm requiring gravity to assist its function. It's essentially all springs and levers. The only thing that comes to mind is when inserting/removing shells from a revolver's cylinder, but even in that case, gravity assist is optional.
I fired my modern 9 MM Luger autoloader several times holding it upside down and it worked just fine. What modern fire arm uses gravity to eject and reload a cartridge?
Do not forget that the lettuce will resist deformation from its resting state. So you can cut it with a sufficiently sharp knife, or through enough momentum with a chopping motion. I would most certainly bet the lash of a carbon nano tube whip would mince apart free floating green space lettuce with hardly any kinetic energy
To restate the above a bit more formally.
The lettuce requires a certain force (more precisely, pressure) in order to cut through it.
To ensure that there is enough force, exerted by the moving knife, the impulse of the collision (force times time) must involve a short enough time during contact for that (reaction) force to be high enough to achieve cutting. That means the knife needs to be traveling fast enough. If the knife is not traveling fast enough, the leaf will be accelerated by the (lower) force and just be pushed forward at the speed of the knife.
Right.. the reason I gave the lettuce example is to distinguish a difference between two objects mainly their mass and their mass still being important on the damage they take even if they are in the vacuum of space.
I mean if you want to neat pick it you can say that and the leaf of lettuce would be instantly freeze dried when exposed to the vacuum of space therefore it would shatter before it could be cut through :)
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 90 ·
  • · Replies 47 ·
