Is it possible to see at high speeds?
  • Context: Graduate
  • Thread starter Thread starter Deepak Kapur
The discussion centers on the question of whether it is possible to see objects, specifically Earth, while traveling at speeds close to the speed of light. Participants explore the implications of relativistic effects on visibility, including Doppler shifts and the perception of distances and sizes at high velocities.
  • Some participants propose that it may be possible to see Earth while traveling at high speeds, but the experience would differ from what Lorentz transformations predict.
  • Consideration of Doppler shifts and varying distances to different points on Earth's surface is highlighted as important for understanding visibility at high speeds.
  • One participant notes that at high speeds, the apparent size of Earth would be significantly reduced compared to the distance traveled in one second, raising questions about the clarity of observation.
  • There is speculation about whether increasing the distance from Earth would improve visibility, but concerns are raised about losing detail and only seeing an oval shape instead of a sphere.
  • Questions are raised about the ability to see small objects, such as a clock, at relativistic speeds and whether high-speed cameras could capture clear images or would also be distorted.
  • One participant challenges the relevance of asking about visibility at near-light speeds if similar effects are already observable at lower speeds, such as 100 kph.
Participants express varying opinions on the feasibility of seeing objects at high speeds, with no consensus reached on the implications of relativistic effects on visibility.
Participants acknowledge the complexity of the problem, including the effects of speed on perception and the limitations of current understanding regarding relativistic optics.
Deepak Kapur
Is it possible to see at high speeds. If we speed past Earth in a spaceship that is traveling near the velocity of light, would we be able to see the Earth at all?
I would think so, although it wouldn't be the same as what the Lorentz transformations specify. (Those provide information about measurements made with distributed clocks, etc.) With regard to seeing fast moving objects, one would need to take into account Doppler shifts, different distances to different points on the object's surface at a give instant, etc. It's an interesting problem.
I meant to say that Earth's diameter/circumference will be extremely-2 small in comparison to the distance that we would cover in one second.
While going very fast in a car we are not able to notice even substantially big things (that are near our car) with clarity even if we are not driving (because they move past us in a very short span of time).
Does it mean that increasing the distance of our spaceship from the Earth would solve the problem to some extent. But what would be the real benefit then, we would just be seeing an oval shaped thing instead of a sphere (what about the details on the Earth's surface)?
Or for that matter would we be able to see small things (say a clock) while moving at speeds comparable to the speed of light. Could high speed cameras help us in this regard or they too would produce distorted/unclear pictures?
If you already know that the velocity-related effect you are interested in is present at 100 kph then why would you even bother to ask if it is present near the speed of light?
Surprisingly, it isn't. See here the correct representation.
  • · Replies 53 ·
  • · Replies 65 ·
14K
  • · Replies 23 ·
  • · Replies 25 ·
  • · Replies 98 ·
10K
