Laplace Eq with Dirichlet boundary conditions in 2D (solution check)
The discussion revolves around solving the Laplace equation for the steady state temperature distribution in a flat metal sheet, subject to Dirichlet boundary conditions. The original poster presents a solution involving a series representation of the temperature function T(x,y) and seeks validation for the coefficients derived in the process.
  • Participants explore the validity of the coefficients in the series solution, particularly questioning the treatment of even and odd indices in the summation. There are discussions about potential index changes and the implications of interpreting T_0 as a constant versus a function of x.
The conversation is active, with participants providing insights into the series representation and coefficient calculations. Some participants express uncertainty about the interpretation of T_0 and its role in the solution, while others confirm the correctness of the calculations presented. There is no explicit consensus, but multiple interpretations and approaches are being explored.
Participants note the importance of correctly summing only over odd indices due to the boundary conditions, and there is an ongoing examination of the assumptions regarding the nature of T_0.
PhysicsMark
The steady state temperature distribution, T(x,y), in a flat metal sheet obeys the partial differential equation:
[tex]\frac{\partial^2{T}}{\partial{x}^2}+{\frac{\partial^2{T}}{\partial{y}^2}}=0[/tex]
Separate the variables and find T everywhere on a square flat plate of sides S with boundary conditions:
[tex]T(0,y)=T(S,y)=T(x,0)=0[/tex]
[tex]T(x,S)=T_0[/tex]
For a solution, I get:
[tex]T(x,y)=\sum_{n=1}^{\infty}\frac{4T_0}{n\pi}sin(\frac{n\pi}{S}x)\frac{sinh(\frac{n\pi}{S}y)}{sinh(n\pi)}[/tex]
I am not sure if I have given a sufficient enough answer for the coefficient of the series. I got the coefficient by doing the following:
[tex]T(x,s)=\sum_{n=1}^{\infty}A_n{sin(\frac{n\pi}{S}x)}sinh(n\pi)=T_0[/tex]
[tex]B_n=A_n{sinh(n\pi)}[/tex]
[tex]B_n=\frac{2}{S}\int_{0}^{S}T_0{sin(\frac{n\pi}{S}x)}dx[/tex]
[tex]B_n=\frac{4{T_0}}{n\pi}[/tex] for "n" odd and 0 for "n" even.
Does anyone know if the coefficient is incorrect?
If even [itex]n[/itex] coefficients are zero, why are you summing over both even and odd [itex]n[/itex] in your final solution?
Are you suggesting an index change? As in swapping out all n's to the right of sigma with m, where m = 2n?
Or changing the n's to n(n+1)?
Well, there are two common ways of doing this:
(1) Replace [tex]\sum_{n=1}^{\infty}[/tex] by [tex]\sum_{n=1,3,5,\ldots}^{\infty}[/tex]
(2) Replace [itex]n[/itex] by [itex]2n+1[/itex]...
[tex]T(x,y)=\sum_{n=1,3,5}^{\infty}\frac{4T_0}{n\pi}sin(\frac{n\pi}{S}x)\frac{sinh(\frac{n\pi}{S}y)}{sinh(n\pi)}=\sum_{n=0}^{\infty}\frac{4T_0}{(2n+1)\pi}sin(\frac{(2n+1)\pi}{S}x)\frac{sinh(\frac{(2n+1)\pi}{S}y)}{sinh((2n+1)\pi)}[/tex]
First, I forgot to thank you for taking the time to reply. Thank you.
Gosh, I see. Sorry about the earlier post. I was thinking of only including the even numbers for some reason.
Would you say that what you have posted above is "as good as it gets"?
I was concerned about how I found the coefficient because I don't think I fully comprehend the term T_0. I read T_0 to be initial temperature. I assumed it was a constant, and treated it as such in the integration of it with the sine term.
My expression for T_0, indicates that it is a function of x.
Is it correct to interpret T_0 as the initial temperature?
If T_0 is a function of x, then are we talking about how the temperature changes from the initial temperature to a lesser temperature as we move away from the source of the initial temperature?
Hey, I think either way is correct. you could do from 1 to inf, and assume that the even numbers are 0, also, you could sum odd number. I followed your way to calculate the Bn, but I got the same answer as the PhysicsMark had.
Yes, everything else in your calculations is correct.
I assume you are worried about the following expression?
Keep in mind, that for [itex]0\leq x\leq S[/itex],
[tex]\sum_{n=0}^{\infty}\frac{4}{(2n+1)\pi}\sin\left(\frac{(2n+1)\pi}{S}x\right)=1[/tex]
which is indeed a constant, not a function of [itex]x[/itex].
The problem is that the expression
[tex]\sum_{n=1}^{\infty}\frac{4T_0}{n\pi}sin(\frac{n\pi}{S}x)\frac{sinh(\frac{n\pi}{S}y)}{sinh(n\pi)}[/tex]
does not imply that the even terms are zero. You need to explicitly sum over only odd [itex]n[/itex].
Ahh, I see. Thanks again.
  • · Replies 16 ·
  • · Replies 18 ·
