| Thread Closed |
Coil length or Solenoid length? |
Share Thread | Thread Tools |
| Apr18-10, 02:39 AM | #1 |
This is not a homework. I am just pretty confused about a problem (with solution!) I saw in the internet found here:
http://www.transtutors.com/physics-h...induction.aspx The part I am confused is the mutual inductance part. Here I repeat the question: 1. The problem statement, all variables and given/known data A long solenoid of length 1 m, cross sectional area 10 cm2, having 1000 turns has wound about its centre a small coil of 20 turns. Compute the mutual inductance of the two circuits. What is the emf in the coil when the current in the solenoid changes at the rate of 10 Amp/s? 2. Relevant equations I am assuming in the question, both coils are wound such that both has the same coil length as the solenoid. 3. The attempt at a solution The mutual inductance [tex]M[/tex] is given as: [tex] M = \frac{\mu N_1 N_2 I_2 A}{l} [/tex] where [tex]l[/tex] is the length is the solenoid length. Suppose the 20 turns coil has shorter coil length. Would that affect the mutual inductance value? |
| Apr18-10, 06:13 AM | #2 |
No. As long as the coil is near the midpoint of the solenoid and its ends do not extend very far from the midpoint, the length of the coil does not matter much. This is an approximate calculation which assumes that the magnetic field generated by the solenoid is uniform at the location of the coil. It is most accurate at the solenoid's midpoint. As you move the coil closer to the ends of the solenoid, the field generated by the solenoid is less and less uniform which makes the approximation less and less valid.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Coil length or Solenoid length?
| Help in The length of a solenoid | Advanced Physics Homework | 0 | ||
| Inductive reactance and length of the solenoid | Introductory Physics Homework | 1 | ||
| Basic Calculus III- Arc Length Parameter and Length- Getting a negative length | Calculus & Beyond Homework | 6 | ||
| A solenoid where radius >> length? | Electrical Engineering | 5 | ||
| The length of a wire forming a solenoid | Introductory Physics Homework | 2 | ||
