Coupled oscillators - mode and mode co-ordinates
The discussion centers on the mathematical modeling of coupled oscillators, specifically two masses M1 and M2 connected by springs. The amplitudes of their displacements are expressed as ψ1(t) = A0 cos(ω+ t) and ψ2(t) = A0 cos(ω+ t). The variables q1 and q2 are defined as q1 = √(m/2)(ψ2 + ψ1) and q2 = √(m/2)(ψ2 - ψ1), which represent the normal modes of the system. The factor √(m/2) is crucial for normalizing the modes, ensuring that the system's behavior can be accurately described in terms of its mass and displacement.
  • Understanding of coupled oscillators and harmonic motion
  • Familiarity with normal mode analysis in mechanical systems
  • Knowledge of mathematical notation for oscillatory motion
  • Basic principles of linear algebra as applied to physical systems
  • Research the concept of normal modes in coupled oscillators
  • Study the derivation of the equations of motion for coupled systems
  • Learn about the mathematical techniques for solving differential equations in oscillatory systems
  • Explore the physical implications of mode coupling in mechanical systems
Students and professionals in physics, particularly those studying mechanical vibrations, engineers working with oscillatory systems, and anyone seeking to deepen their understanding of coupled oscillators and their mathematical descriptions.
joriarty
For this question I'm not going to introduce the particular problem I am working on, rather, I am merely wanting some explanation of a concept which I can't seem to find in any of my textbooks. I suspect the authors think it is just too obvious to bother explaining :smile:.
I'm revising for a test and have the full worked solutions for this problem in front of me. I can follow the mathematics, but not the reasoning behind it.
The question:
Two masses M1 and M2 are connected by springs as in my expertly drawn diagram attached.
Show that the amplitude of the displacement of the masses is described by expressions of the form:
[tex]\psi _{1}\left( t \right)=A_{0}\cos \omega _{+}t[/tex]
[tex]\psi _{2}\left( t \right)=A_{0}\cos \omega _{+}t[/tex]
My worked solutions now say:
Notice that when the system is in mode 1, the quantity (x2 - x1) is always zero, and (x1 + x2) varies harmonically. In mode 2 the reverse is true. Let us define a set of variables:
[tex]q_{1}=\sqrt{\frac{m}{2}}\left( \psi _{2}+\psi _{1} \right)\; -->\; \dot{q}_{1}=\sqrt{\frac{m}{2}}\left( \dot{\psi }_{2}+\dot{\psi }_{1} \right)[/tex]
[tex]q_{2}=\sqrt{\frac{m}{2}}\left( \psi _{2}-\psi _{1} \right)\; -->\; \dot{q}_{2}=\sqrt{\frac{m}{2}}\left( \dot{\psi }_{2}-\dot{\psi }_{1} \right)[/tex]
My question:
What exactly are q1 and q2, and why should these be equal to [tex]\sqrt{\frac{m}{2}}\left( \psi_{2}+\psi_{1} \right)[/tex] etc? Why [tex]\sqrt{\frac{m}{2}}[/tex]? Is there a more specific name for this law that I could look up?
I hope my question is easily understandable! Thank you for your help.
(note: for the sets of equations relating q1 and q2 to m and x, there should be a "≡" sign rather than an "=" sign - for some reason my TEX formatting comes out with "8801;" rather than a "≡" sign. Odd.)
Formulae now fixed. I hope. Sorry if I confused anyone while I was editing things
