Elektron beam strikes in potential barrier
The discussion revolves around an electron beam with a kinetic energy of 10 eV striking a potential barrier, V0. The original poster seeks to determine the potential V0 required for 40% of the beam to be reflected and explores the implications of changing the potential to a negative value. The Schrödinger equation is referenced in the context of analyzing the reflection and transmission of the beam.
  • Participants discuss the calculation of the reflection coefficient and its relationship to the potential barrier. There are attempts to derive k1 and k2 values using the Schrödinger equation and the reflection coefficient formula. Questions arise regarding unit consistency and the implications of using different units for energy and wave vectors.
Some participants have provided calculations and constants, while others have raised concerns about unit conversions and the validity of results. There is an ongoing exploration of how to solve for k2 using the reflection coefficient equation, with multiple interpretations of the results being discussed.
Participants note the importance of using consistent units, particularly in converting energy from eV to Joules and ensuring that all constants are in SI units. There is also a mention of the potential implications of negative potentials on the kinetic energy of the electron beam.
rayman123
Electron beam with kinetic energy [tex]E_{k} = 10 eV[/tex] strikes a positive potential barrier [tex]V_{0}[/tex] and the kinetic energy after the beam has passed through the barrier is [tex]E_{k} = (10 eV -V_{0})[/tex].
How big potential [tex]V_{0}[/tex] is needed so that 40% of the electron beam is going to be reflected?
What would happen if we now make the potential negative so the electron beam will gain the kinetic energy?
I would say that the energy of the particles is higher than the energy of the potential barrier, that's why we observe transmission and reflection
solving The Schrödinger equation
[tex]\frac{\partial^2}{\partial x^2}\psi(x)+\frac{2m}{\hbar^2}[E-V(x)]\psi(x)=0[/tex]
then the solutions will be
[tex]\psi_{1}=Ae^{ik_{1}x}+Be^{-ik_{1}x}[/tex] in the region x<0 [tex]k_{1}= \sqrt{\frac{2mE}{\hbar^2}}[/tex]
[tex]\psi_{1}=Ce^{ik{2}x}[/tex] in the region x>0 [tex]k_{2}= \sqrt{\frac{2m[E-V_{0}]}{\hbar^2}}[/tex]
the reflection coefficient is [tex]R= (\frac{k_{1}-k_{2}}{k_{1}+k_{2}})^2[/tex]
Can someone help me with the solution?
Is the reflection coefficient going to be 0.4? How to find that value of [tex]V_{0}[/tex]
Yes, the reflection coefficient will be 0.4. So just solve for [tex]V_0[/tex] using that equation and knowing E = 10 eV.
I have calculted [tex]k_{1}= \sqrt{\frac{9.1\cdot10^{-31}\cdot16.02\cdot10^{-19}}{(6.626\cdot10^{-34})^{2}}[/tex]=[tex]0.2728[/tex]
[tex]k_{1}= \sqrt{\frac{2mE}{\hbar^2}}= \sqrt{\frac{kg\cdot J}{J^2\cdot s^2}[/tex][tex]=\sqrt{\frac{kg}{N^2\cdot s^2}[/tex]=[tex]\frac{1}{m}[/tex]
then i am trying to solve the equation with R
[tex]R= (\frac{k_{1}-k_{2}}{k_{1}+k_{2}})^2[/tex] to calculate [tex]k_{2}[/tex] and finally calculate [tex]V_{0}[/tex] from the equation for [tex]k_{2}[/tex]
but i am stuck here...
[tex]R= \frac{k_{1}^2-2k_{1}k_{2}+k_{2}^2}{k_{1}^2+2k_{1}k_{2}+k_{2}^2}[/tex]
and then i substitute for R= 04 and for [tex]k_{1}= 0.2728[/tex] does anyone know i am correct so far?
if yes, how would you solve this ?
Hmm... I wouldn't use meters as the units. Try to stick in eV and Angstroms. A couple of useful constants are:
[tex]m_e c^2 = 0.511\,\text{MeV}[/tex]
[tex]\hbar c \approx 2000\,\text{eV}\cdot\text{\AA}[/tex]
But I get a very different answer than your [tex]k_1[/tex]. Remember that the wavelength of a particle is inversely related to the [tex]k[/tex] vector. So you are saying this electron has a wavelength on the order of meters. I think that is something you'd be able to see, which doesn't seem quite right.
hello you are right! I forgot that [tex]\hbars[/tex] is not the same as h!so here is my correct calculation
[tex]k_{1} = \sqrt{\frac{2mE}{\hbar^2}}=\sqrt{\frac{2\cdot9.1\cdot10^{-31}\cdot10eV}{(6.582\cdot10^{-16})^2}[/tex] =[tex]6.48[/tex] is this value correct
i have substituted m in [kg] and [tex]\hbar[/tex] in eVs
why do you mention about Ångström? Do i need to use this unit in any of these calculations?
You converted all the units to SI units except for energy. Why did you leave it as eV? Also what are the units of your [tex]k_1[/tex] in that problem.
the unit for k should be [tex]\frac{1}{m}[/tex]can i express energy in J instead and do the same thing with [tex]\hbar[/tex] and express it in Js?
If you want to solve it in SI units then you need to keep everything in SI units. So yes, convert eV to J, and make sure [tex]\hbar[/tex] is in SI units.
in that case i get very big number...
[tex]\sqrt{\frac{2\cdot9.1\cdot10^{-31}\cdot1.602\codot10^{-18}}{(1.054\cdot10^{-34})^2}[/tex]= [tex]\sqrt{\frac{2.91564\cdot10^{-48}}{1.110916\cdot10^{-68}}[/tex] =[tex]\sqrt{2.624\cdot10^{20}}[/tex] = [tex]1.62\cdot10^{10}[/tex]
which is extraordinary big...dont you think?
It seems very reasonable. Remember that the wavelength of the electron is inversely proportional to the k-vector. So that looks like a wavelength on the order of an angstrom. So that is better looking than meters.
okey i am glad to hear that.
do you have any idea how to solve the equation for R to obtain [tex]k_{2}[/tex] (which should be the next step to calculate [tex]V_{0}[/tex])?
[tex]R= \frac{(k_{1}-k_{2})^2}{(k_{1}+k_{2)})^2}[/tex]
[tex]R(k_{1}+k_{2})^2=(k_{1}-k_{2})^2[/tex]
[tex](\sqrt{R}k_{1}+\sqrt{R}k_{2})^2-(k_{1}-k_{2})^2=0[/tex]
[tex]\left(\sqrt{R}k_{1}+\sqrt{R}k_{2}-k_1+k_2\right)\left(\sqrt{R}k_{1}+\sqrt{R}k_{2}+k_1-k_2\right)=0[/tex]
[tex]\left(\sqrt{R}k_{1}+\sqrt{R}k_{2}-k_1+k_2=0\right)\quad\vee\quad\left(\sqrt{R}k_{1}+\sqrt{R}k_{2}+k_1-k_2=0\right)[/tex]
[tex]\left(-k_1(1-\sqrt{R})+k_2(1+\sqrt{R})=0\right)\quad\vee\quad\left(k_1(1+\sqrt{R})-k_2(1-\sqrt{R})=0\right)[/tex]
[tex]\left(k_2(1+\sqrt{R})=k_1(1-\sqrt{R})\right)\quad\vee\quad\left(k_1(1+\sqrt{R})=k_2(1-\sqrt{R})\right)[/tex]
[tex]\left(k_2=k_1\frac{(1-\sqrt{R})}{(1+\sqrt{R})}\right)\quad\vee\quad\left(k_1\frac{(1+\sqrt{R})}{(1-\sqrt{R})}=k_2\right)[/tex]
but then i get 2 values for [tex]k_{2}[/tex]
  • · Replies 20 ·
  • · Replies 30 ·
  • · Replies 0 ·
