T Flip-Flop Using A D Flip-Flop HDL?
  • Thread starter Thread starter pags920
The discussion focuses on implementing a T Flip-Flop using a D Flip-Flop in Verilog. The user identifies the need for an XOR gate to achieve the toggling functionality of the T Flip-Flop. The provided Verilog module outlines the basic structure of the D Flip-Flop, which outputs the value at the D input on the rising edge of the clock. The key insight is that to toggle the output, the D input should be connected to the inverted output (bar(Q)) of the flip-flop.
  • Understanding of Verilog HDL syntax and structure
  • Knowledge of flip-flop operation, specifically D and T Flip-Flops
  • Familiarity with digital logic design, including XOR gates
  • Basic concepts of synchronous and asynchronous reset in flip-flops
  • Research how to implement XOR gates in Verilog HDL
  • Study the behavior of D Flip-Flops and their timing diagrams
  • Learn about creating modular designs in Verilog for complex circuits
  • Explore simulation tools for testing Verilog code, such as ModelSim or Vivado
Digital circuit designers, Verilog programmers, and students learning about flip-flops and digital logic design will benefit from this discussion.
pags920
I am trying to figure out how to make a T Flip Flop using a D Flip-Flop. I know that I need to use a XOR gate in order to make the T Flip-Flop, but I am having trouble putting it into a Verilog code. Below is the module for the flip-flop. Do I have to create a new module just for the XOR gate or can I incorporate it somehow in the flip flop module?
module T_flip_flop (Q, D, CLK, Clr);
output Q;
input D, CLK, Clr;
reg Q;
always @ (posedge CLK or negedge Clr)
if(~Clr)Q<=1'b0; else Q<=D;
endmodule
I don't know verilog but a D flip flop outputs whatever is at the D input when you clock it.
If you want it to toggle, wire D to bar(Q).
21K
