Are There Multiple Independent Spins in Higher Dimensional Spaces?
The discussion revolves around the concept of spin in higher-dimensional spaces, particularly focusing on dimensions greater than four. Participants explore the implications of having multiple independent spins in such dimensions, referencing theories like Kaluza-Klein and the role of isospin. The conversation encompasses theoretical frameworks, potential papers, and the mathematical underpinnings of spin in various dimensions.
  • Some participants suggest that in 4+1 dimensions, there may be two independent spins, referencing a paper on 5D black holes that supports this idea.
  • Others mention that spin in higher dimensions corresponds to representations of the special orthogonal group SO(n), with complexities arising in lower dimensions.
  • A participant expresses interest in the Kaluza-Klein theory, proposing that if a second spin exists, it could validate the theory and its implications for unifying forces.
  • Concerns are raised about the interpretation of "two spins," with some arguing that spin is a single quantum number in higher dimensions, while others propose a Cartesian product of spin states.
  • Discussions include the relationship between spin and isospin, with some asserting that they are distinct and not intertwined, citing the Coleman-Mandula no-go theorem.
  • Participants inquire about the definition of spin in higher dimensions and the existence of multiple Casimir operators that could define spin differently.
Participants express differing views on the existence and interpretation of multiple spins in higher dimensions. There is no consensus on whether isospin can be considered a manifestation of spin in additional dimensions, and the discussion remains unresolved regarding the implications of Kaluza-Klein theory.
Limitations include the dependence on specific definitions of spin and the mathematical complexities involved in higher-dimensional representations. The discussion also highlights unresolved questions about the relationship between spin and isospin, as well as the implications of the Coleman-Mandula no-go theorem.
Researchers and students interested in theoretical physics, particularly in the areas of higher-dimensional theories, spin representations, and the interplay between different quantum numbers.
haael
Do you know of any papers about spin in dimensions>4? It seems that there are two independent spins in 4+1 dimensions, since you can replace spatial dimension 1 with 2 and 3 with 4, each pair not messing with the other.
I found only one paper on arxiv: <http://arxiv.org/abs/0908.2484> on 5D black holes, where is stated that in 5D indeed there are two spins.
But what about more quantum physics? Did anyone have identified second spin with, say, isospin? Are there any works?
Unsure just what you are looking for but there should be a bunch of papers under String Theory.
Spin in n dimensions is just the theory of representations of SO(n).
There are some surprises for small n, e.g. so(3) = su(2) and so(4) = su(2)+su(2), but for higher n it's just so(n).
I'm looking for a proof of Kaluza-Klein theory or like.
I'm a big fan of this theory and I would be very sad if the fifth dimension I dreamt of as a child simply didn't exist :). Yet, when I had finally understood what spin is, a simple test came to my mind: in 5d there shoul be two spins. So our particles should have some another degree of freedom. If they have it, Kaluza-Klein may be true. If not, farewell hyperspace.
Now I look for some papers that may have explained this. Do we really have such another spin? May isospin be our missing factor? Or maybe this another spin is somehow supressed or unobservable? Or maybe in Minkowski 4+1 spacetime there are no two spins at all? Curiosity is killing me.
I have read some papers on Kaluza-Klein and higher dimensions and they focus on "translation" degrees of freedom, but spin is kind of taboo topic.
However, if Kaluza-Klein was true, it would be simply beautiful. Unified gravity and electromagnetism (and weak interaction, if the second spin was isospin) in a pure geometric way. It can also explain CP violation. Supersymmetry may give us matter. I even read that the dilaton may be the Higgs itself.
So, if you know of any papers about physical consequences of five dimensions on spin, please point me some. Maths is appreciated, but I rather want to proove or disproove Kaluza-Klein.
I do not understand what you mean by "two spins". In higher dimensions spin is just the quantum number that corresponds to representations of SO(N). In higher dimensions the multiplets are more complicated, but it's still one physical quantity.
By the Coleman-Mandula no-go theorem you cannot combine isospin (or some other internal quantum number) with a spacetime symmetry, except for the "trivial" combination. In order to get a kind of intertwining between spin and isospin you need supersymmetry.
Can you please explain what you mean by "two spins"?
Two sets of spin quantum numbers, or a cartesian product of the two if you like.
Say, electron can have states (+1/2) and (-1/2). In 4 spatial dimensions it seems it should be (+1/2,+1/2), (+1/2, -1/2), (-1/2, +1/2), (-1/2, -1/2).
Also, you can define two spin operator vectors that will commute with each other:
[tex]S_i =\epsilon_{ijk} [S_j, S_k][/tex]
[tex]Z_i =\epsilon_{ijk} [Z_j, Z_k][/tex]
Isospin is the only thing that comes to my mind when I try to find interpretation of this another "spin". So, if you convince me that isospin can not be the manifestation of spin in another dimension, I will have to forget about Kaluza-Klein.
Note that this is only my limited knowlegde. I may be just plain wrong.
This is not how spin works in general. In 3-dim. space you have SO(3)~SU(2) which explains the half-integer values. In 4-dim. spacetime you have SO(3,1)~SU(2)*SU(2) which explains the bi-spinor structure of the Dirac equation. But in higher dimensions such a factorization is in general not available.
Spin and isospin are not intertwined. Isospin is invariant under Lorentz boosts and rotations (a rotated proton is still a proton) and vice versa (an iso-rotated proton becomes a neutron but the spin orientation is not affected).
If you want to get a non-trivial intertwining of spin and isospin (or any other internal symmetry) you have to find a loop-hole in the Coleman-Mandula no-go theorem - which could be supersymmetry ...
Dear guys,
I'm also interested in the definition of spin in various dimensions.
For the usual 4D QFT, the definition of spin comes from the other Casimir operator [tex]W_\mu \equiv \frac{1}{2}\epsilon_{\mu\nu\rho\sigma}P^\nu J^{\rho\sigma}[/tex]However, in higher dimensions, we can have defined a lot of Casimir operators, each of them can derive a definition of "spin", so, I am wondering that what is the definition of spin in the usual literature concerning about theories in higher dimensions?
And, what's the general rule to find out all the Casimir operators in a giving symmetry? Thanks!
  • · Replies 58 ·
  • · Replies 23 ·
