What is relativistic mass and rest mass
The discussion centers on the concepts of "relativistic mass" and "rest mass" within the context of physics. Participants explore definitions, measurement methods, and the implications of relative motion on mass measurements, touching on theoretical and experimental aspects.
  • One participant defines rest mass as the mass measured by an observer at rest relative to the object and questions if this applies when the object travels at the same velocity as the observer.
  • Another participant states that relativistic mass can be measured for small particles when their energy exceeds their rest mass, using electrons as an example.
  • There is a suggestion that relativistic mass can be inferred from momentum effects when particles collide, although measuring high-speed particles directly is challenging.
  • One participant asserts that relative velocity is what matters for determining rest mass, not the absolute motion of either the observer or the object.
  • Participants propose that mass can be measured by applying a force to an object and observing its resistance to that force, as well as through deflection experiments involving magnetic fields.
  • Mathematical expressions are provided to illustrate how rest mass can be inferred from experimental setups involving charged particles in magnetic fields.
Participants express some agreement on the definitions of rest mass and relativistic mass, but there remains confusion and uncertainty regarding the measurement methods and implications of relative motion. Multiple viewpoints on how to measure mass in different contexts are presented, indicating that the discussion is not fully resolved.
Limitations include potential misunderstandings of the definitions of rest mass and relativistic mass, as well as the complexities involved in measuring mass for objects in motion. The discussion also highlights the dependence on experimental conditions and the need for clarity in definitions.
Rico L
what is "relativistic mass" and "rest mass"..
as far as i know the rest mass is the mass which measured by an observer who is at rest relative to the object (please correct me if this is not right), if this is right... what if when the object is traveling at the exactly same velocity of the observer.. does "rest mass" also applies to this situation?
relativistic mass is the mass of an object measured by an observer who is moving relative to the object or the mass of an object moving relative to an observer who is measuring the mass entitled to regard himself as stationary. i mean if this is right, in which way, how can the mass be measured if the object is moving.. ?
i am so confused...
thanks
With small particles where their energy when they are moving is larger than their rest mass we can measure their relativistic mass.
So an electron has a rest mass of 511Kev (we even measure rest mass in units of energy) at high speed we can determine it's mass by the momentum effects when it hits something.
But yes it's diffcult to put an electron moving near the speed of light on a set of scales!
This is the same thing as being at rest relative to the observer.
i am so confused...
thanks
It could be measured by applying a small perpendicular force to the object. As it travels by you can measuring by how much it's path changes direction. mass resists force.
It can also be calculated because 2E/v^2 = m so the connections between Velocity and Mass are clear.
Yes, all that counts is the relative velocity between the object and measurer. Either one's relative motion relative to any other reference doesn't matter.
By measuring how much effort it takes to change the velocity of the object.
thanks a lot guys ! :)
Yes, the rest mass can be inferred from deflection experiments :
[tex]m_0=\frac{qB}{\omega \gamma(v_0)}[/tex]
or[tex]m_0=\frac{qBr}{v_0 \gamma(v_0)}[/tex]
where:
B=magnetic induction
q=particle charge
r=radius of the circular trajectory
v_0 = initial speed of the particle when injected in the cyclotron
[tex]\omega=2 \pi/T[/tex]
T=period of particle revolution
  • · Replies 102 ·
  • · Replies 55 ·
  • · Replies 36 ·
  • · Replies 143 ·
10K
