Magnetic Force on Electron near Long Wire
The discussion centers on calculating the magnetic force on an electron located 6 cm from a long, straight wire carrying a 15-A current along the +y axis. The magnetic field generated by the current is directed along the negative z-axis at this position. The right-hand rule is employed to determine the direction of the magnetic field, confirming that it is indeed downward in the context of the x-y plane. The electron's movement at a speed of 10^6 m/s along the +x axis will experience a magnetic force due to this field.
  • Understanding of the right-hand rule for magnetic fields
  • Familiarity with the Biot-Savart Law
  • Knowledge of Lorentz force equation
  • Basic concepts of electromagnetism
  • Study the Biot-Savart Law to understand magnetic field calculations
  • Learn about the Lorentz force equation and its applications
  • Explore the effects of magnetic fields on charged particles
  • Investigate the behavior of currents in different geometries
Physics students, educators, and anyone interested in electromagnetism and the behavior of charged particles in magnetic fields will benefit from this discussion.
lha08
A long, straight wire carries a 15-A current along the +y axis. What is the force on an electron located instantaneously at x= 6 cm and moving with a speed of 10^6 m/s in the following directions:
a) away from the wire along the +x axis?
Like i know that the current is flowing up the y-axis but like i tried using the right hand rule to find the current (my thumb points towards current and fingers curl downwards--so magnetic field is downward..is that right??
I'm not sure what you mean by the magnetic field is "downward"
I've uploaded a picture showing the correct direction of the magnetic field in the x-y plane.[PLAIN]http://img704.imageshack.us/img704/6974/98705090.jpg
so at a point along the positive x-axis, the magnetic field is directed along the negative z-axis.
