Continuous bijection that is not an embedding
  • Context: Graduate
  • Thread starter Thread starter Bacle
    Bijection Continuous
The discussion revolves around the concept of continuous functions between topological spaces, specifically focusing on conditions under which a continuous bijection fails to be an embedding. Participants explore examples, definitions, and implications related to embeddings and subspace topologies.
  • One participant inquires about examples of continuous functions that are bijections but not embeddings, specifically seeking reasonable examples beyond trivial cases.
  • Another participant provides the example of a continuous bijection from the interval [0, 2π) to the circle, defined by f(t) = (cos(t), sin(t)).
  • A participant asserts that the inclusion map from a strict subspace A to X is an embedding only when A has the subspace topology, arguing that for other topologies, the inclusion may not be continuous or open.
  • Another participant clarifies that the definition of embedding requires the subspace topology, suggesting that the initial topology on A does not guarantee the inclusion is an embedding.
  • There is a discussion about the redundancy of stating that an embedding is injective, as being a homeomorphism onto its image implies injectivity.
  • One participant contrasts definitions of embedding in topological spaces with those in differentiable manifolds, questioning the necessity of the more complex definition involving immersions.
  • Another participant explains that the definition of embedding in the context of smooth manifolds incorporates additional structure, specifically the smooth structure, which necessitates the immersion aspect.
Participants express differing views on the definitions and implications of embeddings, particularly regarding the necessity of the subspace topology and the relationship between injectivity and homeomorphism. The discussion remains unresolved with multiple competing perspectives on these definitions.
Participants highlight the importance of topology in defining embeddings and the implications of different topological structures on the properties of inclusion maps. There is uncertainty regarding the sufficiency of various topologies for ensuring that inclusion maps are embeddings.
Bacle
Hi:
Just curious: a continuous function f:X-->Y ; X,Y topological spaces, can fail
to be an embedding because it is not 1-1, or, if f is 1-1 , f can fail to be an
embedding because, for U open in X f(U) is not open in f(X).
Can anyone think of a "reasonable" example of the last case, by reasonable
I mean no spaces with finitely many points, the inclusion map from a space
into itself with a different topology (i.e.: we have (X,T) and (X,T') , and we
use i:X-->X : i(x)=x ) , or maybe or something one could find in
"Counterexamples" book.
If A is a strict subspace of X , then the subspace topology on A guarantees
that i:A-->X , the inclusion, is an embedding. Is this true for other topologies on A.?
Thanks.
X = interval [0,2 pi), Y = circle {(x,y) : x^2+y^2=1}, continuous bijection f(t) = (cos(t),sin(t)).
No. In fact, that is the definition of "subspace topology" ... so for any topology on A other than the subspace topology, the inclusion i is NOT an embedding. Either because i is not continuous, or because i is not open, or both.
Edgar wrote
" No. In fact, that is the definition of "subspace topology" ... so for any topology on A other than the subspace topology, the inclusion i is NOT an embedding. Either because i is not continuous, or because i is not open, or both. "
Thanks, Edgar. I thought the subspace topology was the initial topology with respect
to inclusion, and, given an inclusion:
i:A-->X
the initial topology was (is) , by def., the smallest topology on A, which makes the
inclusion continuous (largest topology being the discrete one, 2A), but
I don't see how it follows that the subspace topology is the only one for which i is
( I am.? :) ) an embedding:
We have A< X a strict subspace ( i.e, A is not all of X ). Given the map : i:A-->X
We want to define a topology on A such that :
1) Continuity of i: For U open in X , i-1(U) open in A.
We have that i-1(U) =U/\A . So we must have U/\A open in A.
Then any topology TA on A must contain the subspace topology.
i.e., TA> (A, subspace) (with > meaning contains)
2) Openness of map i: For V open in A, i(V)=V is open in X . Like you said,
it follows that A must be an open subspace of X, i.e., A is open as a subset
of X.
How does it then follow that the only topology that makes i:A-->X
into an embedding is (A, subspace) .?. I don't see how we can conclude,
e.g.,
(A, subspace)> TA
Instead of `No. In fact, that is the definition of "subspace topology"', I think g_edgar should have written `No. In fact, that is the definition of "topological embedding"'.
Let X,Y be topological spaces. A function f:X->Y is an embedding if
* f is injective, and
* f is a homeomorphism onto its image f(X), where f(X) carries the subspace topology of X.
So the requirement of "subspace topology" is part of the definition of embedding.
Doesn't your second *, that f is a homeomorphism onto its image f(X), automatically mean that f is injective, your first *?
Yes, you are right, the first * is superfluous. So, in short, an embedding is a homemomorphism onto its image.
That makes really good intuitive sense. But for some reason the book I have defines embedding in a slightly esoteric way. Instead of topological spaces, it talks about embedding of differentiable manifolds.
First it defines an immersion. Basically, a smooth map f: M -> N between manifolds induces a map called the "differential map" f* between the vector spaces of the two manifolds:
f*: T(M) -> T(N) (explicitly, this map happens to be the Jacobian).
If f* is an injection, then f is said to be an immersion.
In addition, if f is an injection, then f is said to be an embedding.
This definition of an embedding seems weird to me, not as nice as your definition. Is there a reason why one would define an embedding in this way?
Remember, we were talking about topological spaces, i.e. spaces with as additional structure (only) a topology. My definition was of a topological embedding, which is just called an embedding if the context (namely, topology only) should be clear.
In your book it is about (smooth) manifolds: those are first of all topological spaces, but they also have extra structure, namely a smooth structure (atlas). An embedding between smooth manifolds, let us call it a smooth embedding to be sure, also has to deal with this smooth structure, and that is the immersion part.
So, a smooth embedding is a topological embedding which is at the same time an immersion (= injective differential).
  • · Replies 20 ·
  • · Replies 43 ·
