Calculating velocity in a slingshot
The discussion focuses on calculating the initial velocity of a projectile launched from a slingshot, specifically a fixed-height slingshot at 48 cm. The participant utilized Hooke's law to determine the spring constant (k) and calculated potential energy to find the initial velocity. However, they encountered discrepancies in the expected horizontal distance traveled, attributing the issue to potential calculation errors related to SI units. The participant concluded that the elasticity of the rubber band affects the spring constant but did not significantly impact their final calculations.
  • Understanding of projectile motion principles
  • Familiarity with Hooke's law and spring constants
  • Knowledge of potential and kinetic energy conversion
  • Basic proficiency in unit conversions, particularly SI units
  • Study the principles of conservation of mechanical energy in projectile motion
  • Learn how to accurately apply Hooke's law in real-world scenarios
  • Investigate the effects of air resistance on projectile trajectories
  • Explore advanced methods for measuring spring constants in non-ideal materials
Students in physics, educators teaching mechanics, and hobbyists experimenting with projectile motion and slingshot dynamics.
skorned
I launched a projectile from a slingshot to different distances by pulling the band back different distances. The projectile was launched horizontally, and the slingshot was a fixed height, 48 cm, above ground.
Known Data for the first run:
Height: 48 cm
Distance the band was pulled back: 4 cm
Force on the band at this stretched point: 1 N
Average distance the projectile traveled after launch: 17 cm
Mass of projectile: 100 gm
Now I need to know how to find the initial velocity of the projectile when it leaves the slingshot, so I can theoretically determine how far the projectile ought to have gone.
s = ut + 1/2 at2
Potential Energy of Spring = 1/2 kx2
Using the force and the extension, I determined k from Hooke's law. Then, using k and extension, I found the potential energy in the spring. Assuming all this energy got converted to kinetic energy, I equated this potential energy to 1/2 mv2. Using the known mass of the projectile, I was able to calculate the velocity of the projectile at launch.
However, using the height, gravitational acceleration, and the knowledge that the initial vertical velocity was 0, I was able to calculate the time the projectile was in motion for. Then, using the initial velocity of the projectile derived earlier, and the time, I calculated the horizontal distance it should have covered ignoring air resistance. However, the values didn't work out right.
Can you tell me where I'm going wrong, or suggest your own method for calculating the velocity of a projectile after it is launched from a slingshot.
If I were to do this, I would trust the projectile motion calculation for finding the initial horizontal velocity. I would also trust conservation of mechanical energy, i.e. that the potential energy stored in the rubber band is converted to kinetic energy of the projectile. I would not trust the validity of Hooke's Law which rubber bands do not generally obey. They also show "hysteresis", i.e. the force they exert depends on what was previously done to them and for how long. In short, I would not assume that the potential energy in the "spring" is (1/2) kx2.
There is a simple test. Hang different masses from your rubber band and measure how much it stretches for each mass. Plot mg vs. x and see if you get a straight line. If you do, Hook's Law is valid and the slope is the spring constant. Repeat your measurements a few times and see how reproducible the results are.
Holy ****, as I begin writing this post, there's this strong feeling of deja vu hitting me.
Anyhow, yes, I am aware of the problems of inelasticity. However, it doesn't matter, since the elasticity was calculated after each experiment, and that was the value used. The consistency of the elasticity didn't matter so much. The spring constant did reduce a lot during the course of the experiment, indicating a decrease in elasticity, but that didn't affect my calculations in any way.
I have got my calculations in place now, I think it was just a calculation error due to SI units not being used. Its fixed now. Thanks for your suggestion though, kuruman.
  • · Replies 35 ·
  • · Replies 38 ·
28K
