15th derivative of a binomial/maclaurin series
  • Thread starter Thread starter karadda
    Derivative Series
The forum discussion focuses on deriving the Maclaurin series for the function sqrt(1+x^4) using the binomial series. The user successfully expresses the series as Σ (k n) (x^(4n)) from n=0 to infinity. To find the 15th derivative at 0, the relationship between the coefficients of the Maclaurin series and the derivatives of the function at zero is emphasized. The discussion highlights the importance of recognizing the pattern in the series expansion to compute higher-order derivatives.
  • Understanding of binomial series expansion
  • Familiarity with Maclaurin series and its coefficients
  • Knowledge of calculus, specifically derivatives
  • Ability to manipulate summation notation
  • Study the properties of binomial series in detail
  • Learn how to derive Maclaurin series for various functions
  • Explore techniques for calculating higher-order derivatives
  • Investigate applications of series expansions in mathematical analysis
Students studying calculus, particularly those focusing on series expansions and derivatives, as well as educators looking for examples of binomial and Maclaurin series applications.
karadda
sqrt(1+x^4)
use the binomial series to find the maclaurin series for the above function. then use that to find the 15th derivative at 0.
-binomial series
I've gotten to:
[tex]\Sigma[/tex] (k n) (x^(4n))
How can i use this to find derivatives?
i haven't checked what you've got to...
but if you write out the form for a maclaurin series in terms of its dereivatives, fror ecach term, notice the power of x & the order derivative in the coefficient are always the same
[tex]f(x) = f(0) + \frac{f'(0)}{1!}x+\frac{f^''(0)}{2!}x^2+..+\frac{f^{n}(0)}{n!}x^n+..[/tex]
[tex]f(x) = f(0) + \frac{f^{1}(0)}{1!}x^1+\frac{f^{2}(0)}{2!}x^2+..+\frac{f^{n}(0)}{n!}x^n+..[/tex]
  • · Replies 38 ·
  • · Replies 16 ·
