Putting an equation in quadratic form
  • Context: High School
  • Thread starter Thread starter miahmad
    Form Quadratic
The discussion focuses on transforming the equation Q(x,y,z) = 7x² - 2y² - 40z² - 14xz + 20yz into quadratic form. The final result is expressed as 7(x-z)² - 2(y-5z)² + 3z². The process involves completing the square for the x and y terms separately while balancing the z² term at the end. Key steps include identifying coefficients and constants to match the original equation's terms accurately.
  • Understanding of quadratic equations and their forms
  • Knowledge of completing the square technique
  • Familiarity with polynomial manipulation
  • Basic algebraic skills
  • Study the method of completing the square in quadratic equations
  • Explore polynomial identities and their applications
  • Learn about transformations of multivariable quadratic forms
  • Investigate the geometric interpretation of quadratic equations
Students and educators in mathematics, particularly those focusing on algebra and quadratic equations, as well as anyone interested in advanced polynomial manipulation techniques.
miahmad
Could someone please explain how to go about putting an equation into quadratic form.
e.g:
Q(x,y,z)=7x^2-2y^2-40z^2-14xz+20yz.
I know it equals 7(x-z)^2 -2(y-5z)^2 +3z^2. dnt know how to get there though.
Dnt wrry figured it out.
What you want to do is first make a square which gets all the x terms right, then a square which gets all the y terms right, but without touching the x. Then in the end, you can use the z2 term to balance the z's.
So, for example, with an x you have 7x2 and -14xz.
If you write c (x - a)2, you will get terms with c x2 and 2 x a c, and stuff with a2, which you can cancel by -a2 terms, if you need. So you can reproduce these two terms by taking c = 7, a = -z.
Then you do the same with the y, choosing numbers c and a such that you exactly get the right y2 and yz terms.
Then, you multiply out everything you have so far. If you did it right, all the terms will match, except possibly those with only z2. Since z2 is itself a square, you can easily fix this by adding the appropriate amount of z2 at the end, and you're done.
  • · Replies 20 ·
20K
