Need help with this as soon as possible please (fluid flow in pipes)
  • Thread starter Thread starter MTRX
    Flow Pipes
The discussion revolves around calculating the required pressure at the outlet of a pump in a chemical processing plant for delivering Benzene. The parameters include a pressure requirement of 550 kPa at point B, a vertical distance of 21 m from point A, and a smooth plastic pipe of 240 m with a diameter of 50 mm. The volume flow rate is specified as 110 L/min, with Benzene's relative density at 0.86 and viscosity at 4.2 x 10-4 Pa.s. The calculation involves applying Bernoulli's equation and the Darcy-Weisbach equation to determine the necessary pump pressure.
  • Understanding of Bernoulli's equation
  • Familiarity with the Darcy-Weisbach equation for head loss
  • Knowledge of fluid properties such as density and viscosity
  • Basic skills in unit conversion and flow rate calculations
  • Study the application of Bernoulli's equation in fluid dynamics
  • Learn how to calculate head loss using the Darcy-Weisbach equation
  • Research the properties of fluids, focusing on density and viscosity
  • Explore pump selection criteria based on flow rate and pressure requirements
Chemical engineers, process engineers, and students studying fluid mechanics who need to understand pump calculations and fluid flow in piping systems.
MTRX
need help with this! as soon as possible please (fluid flow in pipes)
here is my Q am facing a problem with i don't know how to start and i have to hand it in at 9 a.m
Q: In a chemical processing plant, a fluid (Benzene) must be delivered to point B with a pressure of 550 kPa. A pump is located at point A 21 m below point B, and the two points are connected by 240 m of plastic pipe (smooth pipe) having an inside diameter of 50 mm. If the volume flow rate is 110 L/min, calculate the required pressure at the outlet of the pump.
Take relative density of benzene  = 0.86 and its viscosity  = 4.2 x 10-4 Pa.s
here is the drawing click the link below:-
http://www10.0zz0.com/2010/04/29/01/629184696.jpg
pleasez guys help i tried to come up with something, but nothin came up =(
i know the rule is u don't do ours homework, but this time am stuck i don't know how to start and continue with it , so pleasez help
no one can could answer it !
am waiting =(
  • · Replies 38 ·
  • · Replies 31 ·
12K
