Solve the Challenging Redox Chemistry Problem: KNaC4H4O6 + KMnO4 + HNO3
  • Thread starter Thread starter chem_tr
The discussion revolves around a challenging redox chemistry problem involving the reaction of potassium sodium tartrate (KNaC4H4O6) with potassium permanganate (KMnO4) in the presence of nitric acid (HNO3). Participants explore the complexities of balancing the chemical equation and the theoretical calculations of atomic valence in organic substances.
  • Some participants note the difficulty and time-consuming nature of the problem, suggesting that it requires advanced redox chemistry skills.
  • One participant mentions that the exact valence of carbon atoms in tartrate is unclear, proposing that an average value may be used for calculations.
  • Another participant questions the choice of solvent and the role of nitric acid, asking whether it serves as a proton source or an oxidizer.
  • There is a suggestion that the solvent should be aqueous, as alcohol could interfere with the reaction by being oxidized by permanganate.
  • Participants discuss that while the reaction can be approached qualitatively, a quantitative approach would require a full balanced equation to determine the correct concentration of permanganate.
  • One participant clarifies that nitric acid acts only as a proton source in the context of this reaction, while permanganate is the sole oxidizer.
Participants express varying views on the importance of solvent choice and the role of nitric acid, indicating that there is no consensus on these aspects. The discussion remains unresolved regarding the specifics of the balanced equation and the implications of different conditions.
Participants acknowledge that the problem involves multiple sets of redox chemistry due to the different types of carbon in tartrate, and that assumptions about solvent and acid type may affect the outcome of the calculations.
chem_tr
I wanted to share a good question with you. It uses your redox chemistry skills as well as theoretical atomic valance calculation of organic substances. However, nobody managed to solve this problem as it is sufficiently time-consuming and somewhat difficult.
Write the full-balanced equation of potassium sodium tartrate (KNaC4H4O6; see the attachment) with potassium permanganate in the presence of nitric acid. Note that the orientations of alcoholic OH groups are not important in this question.
Hint: I can give a reaction of oxalic acid (HOOC-COOH) in this way:
5*[C(3+) ---> C(4+) + e(-)]
Mn(7+) + 5e(-) ---> Mn(2+)
5C(3+) + Mn(7+) ---> 5C(4+) + Mn(2+)
10C(3+) + 2Mn(7+)---> 10C(4+) + 2Mn(2+)
5 H2C2O4 + 2 KMnO4 + 6 HCl ---> 10 CO2 + 2 MnCl2 + 2 KCl + 8 H2O
Hint2: Note that tartrate contains two kinds of C atoms; alcoholic and carboxylic, so two different sets of redox chemistry is involved altogether.
If you have enough time to deal with a challenging question, give it a try.
Regards
chem_tr
Chemistry news on Phys.org
it's certainly time consuming
Online Chemistry Resource
http://groups.msn.com/GeneralChemistryHomework/_whatsnew.msnw
You are not wrong, but one of my teachers told other students that the exact valence of carbons are not clear and therefore an average value may be proposed for several years, and I tried hard to determine if a valid valence is present.
Since the time I solved that puzzle-like question, I am very comfortable with redox-chemistry questions; this is one of the most difficult ones. So if anybody has a difficulty with redox chemistry, it may be useful to make an attempt to solve it.
Regards
chem_tr
Regards
chem_tr
What is the solvent? Water? Some alcohol?
What is the function of the Nitric Acid?
Proton source? Oxidizer?
What is its molar concentration?
thanks for your interest
Hello,
As you see the reaction below, our assumption is qualitative, so the choice of solvent, type of acid, etc. is not very important:
But you are right of course, we may try to solve this question in terms of quantitative basis; tartrate can be a good primer standard for determining permanganate factor. If you want to find the factor (correct concentration) of a permanganate solution with tartrate, you must write the full balanced equation for correct calculation.
So let's say this question has nothing to do with molar concentrations and even the type of acid.
The solvent should be an aqueous type because alcohol is readily oxidized by permanganate to give acetaldehyde and even acetic acid; therefore should not be used here. Nitric acid is only proton source in our example;permanganate is the only oxidizer in this question. As an acid, you may use HCl, HClO4, or H2SO4. You will obtain manganese(II)nitrate, potassium and sodium nitrate, etc. in the resulting solution if you use nitric acid.
Regards,
chem_tr
17K
22K
11K
