Ideal gas law practical application
The discussion revolves around applying the ideal gas law to determine the depth a bird dives underwater based on pressure changes in a sealed tube attached to it. The problem involves concepts from fluid dynamics and thermodynamics, particularly relating to pressure, volume, and density.
  • Participants explore the relationship between the pressure of air in the tube and the pressure exerted by water at depth. There are attempts to apply the ideal gas law and Bernoulli's equation to relate the initial and final states of the gas in the tube.
Some participants have provided calculations and results based on their interpretations of the problem. There is acknowledgment of potential errors in calculations, and some have verified the correctness of earlier attempts. Multiple interpretations of pressure measurement units and the final length of the tube are being discussed.
There is a mention of specific assumptions, such as constant temperature and the density of ocean water. Participants also note the importance of using consistent units in calculations.
astrophysicsm
To measure how far below the ocean surface a bird dives to catch a fish, a scientist uses a method originated by Lord Kelvin. He dusts the interiors of plastic tubes with powdered sugar and then seals one end of each tube. He captures the bird at nighttime in its nest and attaches a tube to its back. He then catches the same bird the next night and removes the tube. In one trial, using a tube 7.40 cm long, water washes away the sugar over a distance of 2.46 cm from the open end of the tube. Find the greatest depth to which the bird dived, assuming the air in the tube stayed at constant temperature. (Assume the density of the ocean water is 1030 kg/m3.)
Ideal gas law:
PV=nRT
Density = m/V
I think this might have to do with the pressure of the air inside the tube and the pressure at the desired water depth. I can apply this given the change in volume, however, only length is provided and the volume of the tube is not known. I can replace the volume by mass/density in the equation:
P.(m/D) = nRT
But I'm stuck at this point.
Thanks for any help in advance!
astrophysicsm
Air in tube:
State 1 (the bird is flying):
V1 = tube length * tube area
P1 = Patm
State 2 (the bird is diving):
V2 = compressed length * tube area
P2 = Patm + Pwater
Given: T1 = T2
To find Pwater, use Bernoulli (assuming the bird is at rest when at deepest depth)
Compare state 1 with state 2 using the ideal gas law.
Thank you ! :)
I used the ideal gas equation to find final Pressure:
Pf = (Pi Li /Lf)
Using Bernoulli's equation:
Pf=Psurface+Dgh
I ended up with:
h= [(PiLi/Lf) – Pi]/Dg = 4.99m
Can anyone verify this is correct ?
What are you measuring Pressure in. Shouldn't it be in Pascals so 1 atm = 101325 Pa
So therefore, height = 20.16m?
You made an error in your calculation. The final length Lf isn't 2.46 cm, it is (7.4-2.46=4.94)cm
If you use this value you will get astrophysicsm's answer, which is correct. (I made the same mistake you did).
Hey guys,
Your post had helped me.
here is what I did on Maple, and you are right, Lf is the difference.
> h = ((101325*0.74e-1)/(0.74e-1-0.246e-1)-101325)/(1030*9.8);
h = 4.998750614
... and your 4.99 attempt was right.cheers
  • · Replies 35 ·
  • · Replies 23 ·
14K
