Geodesic curves for an ellipsoid
The discussion focuses on calculating geodesic curves on an ellipsoid, specifically addressing the shortest distance between two points on Earth using different equatorial and polar radii. The user has previously solved similar problems for a sphere using Christoffel symbols and geodesic equations but is uncertain about the treatment of constants a and b for the ellipsoid. It is established that a and b are constants, and the user must differentiate with respect to the independent variables theta and phi while calculating the metric tensor and Christoffel symbols.
  • Understanding of geodesic equations and their application
  • Familiarity with Christoffel symbols and their calculation
  • Knowledge of metric tensors in differential geometry
  • Basic concepts of ellipsoidal coordinates
  • Study the derivation of Christoffel symbols for ellipsoidal coordinates
  • Learn how to compute the metric tensor for an ellipsoid
  • Explore the application of geodesic equations in non-spherical geometries
  • Investigate numerical methods for solving ordinary differential equations (ODEs) related to geodesics
Mathematicians, physicists, and engineers involved in geodesy, differential geometry, or any field requiring the calculation of shortest paths on curved surfaces.
tossin
The problem asks to find the shortest distance between two points on Earth, assuming different equatorial and polar radii i.e. the coordinates are represented as:
x = a*cos(theta)*sin(phi)
y = a*sin(theta)*sin(phi)
z = b*cos(phi)
I've already done this for a sphere and it was pretty straightforward: Find the Christoffel symbols, then plug them into the geodesic equations and solve the system of ODEs for the geodesic curves. However, now I'm stuck at the beginning because I'm unsure how to treat a & b. Previously, for spherical coordinates:
x = r*cos(theta)*sin(phi)
y = r*sin(theta)*sin(phi)
z = r*cos(phi)
I calculated the metric tensor treating r, theta, and phi as variables, but when plugging into the geodesic equations, I assumed r was constant so that all derivatives of r were zero. Currently, I'm not sure whether I need to calculate new Christoffel symbols for the ellipsoid or whether I simply need to keep the derivatives of r in the geodesic equations. If the former is true, do I treat a and b as separate variables when calculating the metric tensor? I could use a little direction here. Thanks.
The numbers a and b are constants, just as r was in the spherical case. As the ellipsoid is a surface, you have two independent variables that you need to differentiate with respect to, i.e. theta and phi.
The Christoffel symbols are therefore on the form \Gamma_{\theta \theta}^{\theta}, \Gamma_{\theta \theta}^{\phi} etc. Several of these will be zero due to symmetry around the z-axis.
  • · Replies 16 ·
