Temperature of Cosmological Constant
The discussion revolves around the relationship between temperature and the cosmological constant, particularly in the context of dark energy and virtual particles. Participants explore theoretical implications and potential measurable effects of these concepts.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant suggests that the cosmological constant, linked to dark energy, could be associated with a measurable temperature due to the continuous creation and annihilation of virtual particle pairs.
  • Another participant challenges the idea by stating that using virtual particles to predict the cosmological constant is flawed because the predicted size is significantly larger than observed, by about 120 orders of magnitude.
  • A follow-up question from the same participant seeks clarification on whether separate virtual particle pairs can interact to produce real particles.
  • Another participant mentions black hole evaporation as a theoretical framework that somewhat aligns with the initial suggestion, where one particle of a pair escapes while the other is absorbed by the black hole.
Participants express differing views on the validity of using virtual particles to explain the cosmological constant, indicating a lack of consensus on the topic.
The discussion highlights the complexity of the relationship between virtual particles and the cosmological constant, with unresolved questions regarding the interactions of virtual particle pairs and their implications for observable phenomena.
Readers interested in theoretical physics, cosmology, and the implications of dark energy may find this discussion relevant.
friend
Is there a temperature related to the cosmological constant?
As I understand it, the cosmological constant is produced by dark energy and is a form of zero point energy created by virtual particles and antiparticles being created and annihilated all the time. It seems to me that this process could produce a temperature that might be measureable. With particles pairs being created and annihilated everywhere at all times, it seems likely that a virtual particle created somewhere might collide with another virtual particle created nearby and prevent some virtual particles from annihilating with the partener it was created with. The net result would be creation of real particles creating a background radiation which we might be able to measure. Or do all such virtual pairs travel right through each other like bosons?
The idea of using virtual particles to predict the cosmological constant suffers from one fatal flaw - the size predicted is about 120 orders of magnitude too large.
I guess I'm asking if separate virtual particle pairs can interact with each other and produce real particles.
The only theory (I know of - I'm no expert) that seems like your suggestion is black hole evaporation, where one of the pair escapes and the other is absorbed in the black hole.
  • · Replies 62 ·
13K
  • · Replies 0 ·
