U substitution or substitution by parts?
The discussion revolves around the integration of the function ∫(e^√x/√x) dx, focusing on whether to use u-substitution or integration by parts as the method of integration.
  • Exploratory, Mathematical reasoning
  • Participants explore the use of u-substitution, specifically considering u = √x, and discuss the implications of this choice on the integration process.
Participants are actively engaging with the problem, with some suggesting potential substitutions and others questioning how these substitutions relate to the integrand. There is a collaborative effort to clarify the integration technique being considered.
One participant notes confusion regarding the notation used in their posts, indicating a possible barrier to clear communication in the discussion.
mickellowery
∫〖e^√x/√x dx〗
would this be a u substitution or a substitution by parts?
I would go with an ordinary substitution. The other technique you mentioned is usually called integration by parts.
oh oops I meant to say integration by parts. So would I let u= sqrt(x)?
That would be a good thing to try. What does that lead to?
So if u= sqrt(x) du= 1/2 x^-1/2 and now I'm a little lost because the du doesn't look like it helps me.
Better written as
[tex]du = \frac 1 {2\sqrt x}\, dx[/tex]
Now take a look at what you are supposed to integrate. Does the integrand involve anything that looks like the above?
Alright I think I see it but I want to check. Would I write it as 1/2 ∫〖e^u du〗?
Yes.
BTW, what's the deal with the brackets and parentheses?
Thanks so much for your help DH. I don't know the deal with the brackets and parentheses. I have been using microsoft word's equation writer because I'm not too sure how to use the equation writer on here. Thanks again!
  • · Replies 28 ·
