How can we prove 0.9999... is equal to 1?
  • Context: Undergrad
  • Thread starter Thread starter losin
The discussion revolves around the question of whether the repeating decimal 0.9999... is equal to 1. Participants explore various approaches to proving this equality, including definitions of repeating decimals, limits of sequences, and properties of supremums.
  • One participant suggests proving that 0.9999... is the supremum of numbers smaller than 1.
  • Another participant emphasizes the need for a rigorous definition of repeating decimals and proposes that 0.9999... is the limit of the sequence 0, 0.9, 0.99, 0.999, ... which converges to 1.
  • Some participants argue that they want to show 0.9999... is strictly the same as 1, rather than just showing convergence of the sequence.
  • A claim is made that 1.00..01 is greater than 0.999... and that both limits tend to 1, using the Dedekind's cut principle to assert 0.999... = 1.
  • There are references to multiplying fractions and decimals, specifically discussing the relationship between 1/3 and 0.3333..., and how this relates to 0.999... being equal to 1.
  • One participant mentions the convergence of series and provides a proof using the formula for the sum of an infinite geometric series to show that 0.999... equals 1.
  • Another participant expresses skepticism about the relevance of certain posts, indicating a desire to maintain focus on rigorous proofs.
Participants express differing views on how to approach the proof of 0.9999... being equal to 1. Some agree on the importance of limits and sequences, while others propose alternative methods such as using supremums or geometric series. The discussion remains unresolved with multiple competing views present.
Some participants reference foundational concepts in mathematics, such as limits and convergence, which may not be universally accepted or understood by all contributors. There is also mention of axioms for the reals, indicating potential differences in foundational assumptions among participants.
losin
0.9999... = 1
i want to show 0.9999...=1
by showing 0.9999... is a supremum of numbers smaller than 1,
i would be able to prove it.
how can i show 0.999... is a supremum of numbers smaller than 1?
This is a common question on the forums. Do a search.
If you want to create a hard proof of the statement: 0.999... = 1, you first need to give a rigorous definition for a repeating decimal. The usual definition is it's the LIMIT of the sequence created by appending digits one at a time:
So 0.9999... is the limit of the sequence 0, 0.9, 0.99, 0.999, 0.9999, ...
Using this definition, the proof is simply to show that that sequence converges to 1.
i want to show 0.9999... is strictly same as 1,
not sequence 0.9, 0.99, 0.999, ... converges to 1.
1.00..01 > 0.999... > 0.99...9 for all finite decimals. Both the limits tend to 1. By the Dedekind's cut principle, 0.999... = 1. Q.E.D.
Yes, but what is 0.999...?
It's the limit of the sequence 0.9, 0.99, 0.999, ... .
Therefore, showing that sequence converges to 1 is the proof.
can i show 0.9999...=sup{x|real number less than 1} ?
See my above post.
Dickfore said:
1.00..01
What could you possibly mean by this?
[tex] 1 + \frac{1}{10^{n}}[/tex]
1/3 = .3333333...
Multiply both sides by 3 and see what you get.
By the way, this is assuming that you have established that 1/3 = .33333... in the first place.
Anonymous217 said:
1/3 = .3333333...
And also, [itex]3 \times 0.333... = 0.999...[/itex]
^I don't get the point of your post, but okay.
We start multiplying from the rightmost digit. What is the rightmost digit of 0.333...?
You only start from the rightmost digit because it's convenient not to have the carries messing up what you've already written down. I quite often multiply from left to right.
But really its just the result that if [itex]\Sigma a_n[/itex] converges, [itex]\Sigma ka_n[/itex] converges to [itex]k\Sigma a_n[/itex].
lol.
It saves working out how much space to leave before you start writing it down. Mind you I do quite often get it wrong, but then that applies if I go the other way as well.
Please refrain from off-topic posting. The OP wanted a rigorous proof and you are talking about your arithmetical adventures.
Sorry.
The comment about convergence is a proof. That is [itex]0.\={3}[/itex] is defined as [itex]\sum_{0}^{\infty}3\times 10^{-r}[/itex], so if you've proved this converges to [itex]\frac{1}{3}[/itex] you can say [itex]\sum_{0}^{\infty}3\times 3\times 10^{-r}=\sum_{0}^{\infty}9\times 10^{-r}=0.\={9}[/itex] (by definition) converges to [itex]3\times \frac{1}{3}=1[/itex].
This doesn't mean that showing [itex]0.\={3}=\frac{1}{3}[/itex] is any easier than showing [itex]0.\={9}=1[/itex] in the first place, so I wouldn't personally recommend this route.
Sorry.
Is this proof acceptable?
[tex]0.\={9} = 0.999... = 0.9 + 0.09 + 0.009 + ... = \sum_{k=1}^{\infty} \frac{9}{10^k} = \frac{9/10}{1-1/10} = 1[/tex]
Using the infinite geometric series formula, of course.
That would obviously depend on losin.
The formula for the sum of an infinite gp depends on some basic results about limits, e.g. [itex]|x|<1[/itex] implies [itex]\lim_{n\rightarrow \infty}x^n=0[/itex].
It sounds to me as if losin may be working from axioms for the reals at a stage before much in that way has been proved, in which case he may prefer a direct proof from the axioms using the fact that the [itex]n^{th}[/itex] partial sum for [itex]0.\={9}[/itex] is [itex]1-\frac{1}{10^n}[/itex]. This seems to fit in more with his posted ideas.
When I said that showing [itex]0.\={3}=\frac{1}{3}[/itex] is no easier than showing [itex]0.\={9}=1[/itex], I didn't in any way mean to imply either was particularly hard, so I'm sure losin will soon settle on a proof he finds satisfactory even if it doesn't necessarily correspond with any of the suggestions on the forum.
  • · Replies 24 ·
