Why Are Coefficients of x Plotted on the y-Axis in Linear Combinations?
The discussion revolves around the representation of coefficients in linear equations and their graphical interpretation, particularly why coefficients of variables are plotted on the y-axis in the context of linear combinations. The scope includes mathematical reasoning and conceptual clarification regarding vector representation in linear algebra.
  • One participant expresses confusion about why the second element of the first vector (-6) is plotted on the y-axis, questioning the labeling of axes in relation to the coefficients of the equations.
  • Another participant suggests that if different variables (u and v) were used instead of x and y, it might represent a different problem, implying that the choice of variable names can affect interpretation.
  • A third participant clarifies that the "x" and "y" used as coefficients in the vectors are not the same as the x and y labeling the axes, suggesting that different terminology might reduce confusion.
  • Another participant introduces the idea that each component of a vector can be thought of as representing a new axis, indicating that the presence of "x" in front of a vector does not imply that all components are on the x-axis.
Participants express differing views on the interpretation of variable names and their implications for graphical representation. There is no consensus on the best way to label or interpret these axes and coefficients.
The discussion highlights potential confusion arising from the use of variable names in mathematical expressions and their graphical representations. The relationship between coefficients and their corresponding axes remains unresolved.
Readers interested in linear algebra, vector representation, and graphical interpretation of mathematical equations may find this discussion relevant.
mirza21
I have to linear equations
3x + 2y =7 and -6x + 6y= 6
when expressed as linear combination in column vector form they become:
x[3,-6] + y[2,6] = [7,6]
when solving this linear combination graphically ,First vector is plotted
like this x=3, y=-6 and second vector is plotted like x=2, y=6 as per
textbook
1) first vector contains x coeffceints of equation 1 and 2. I am consfused why second element of first vector(-6) is plotted on y axis. It is x element as per equation 2. Please clarify on this why this done like
this?
I assume the problem is to solve the equation that you write as x[3,-6] + y[2,6] = [7,6]. Suppose you had been asked to solve the equation u[3,-6] + v[2,6] = [7,6] instead. Would that have been a different problem?
In other words, the "x" and "y" used as coefficients for the vectors are NOT the "x" and "y" labeling the axes. It would, indeed, be better not to use "x" and "y" in the equation as Fredrick suggests.
Each component of a vector can be though of as a "new axis", much like the x and y axes.
Take a vector (a, b, c, d)
In the coordinate system you are familiar with, a would be the x-axis value, b the y-axis, c the z-axis, d the t-axis... etc and you can go to as many axes as you want
so even though you see an x in front of (3, -6) it does not mean that every component in that vector is on the x-axis it just means that x is some quantity multiplied by each component that lies on it's own independent axis
