Why did my electroless nickel plating process fail on AISI 316 stainless steel?
  • Thread starter Thread starter gabriel
The discussion revolves around the challenges faced in the electroless nickel plating process on AISI 316 stainless steel. Participants explore potential reasons for the failures, alternative surface treatments, and the specific application context for the plating.
  • One participant reports repeated failures in the electroless nickel plating process on AISI 316 and seeks insights into possible reasons and relevant literature.
  • Another participant questions the specific process being used and provides links to resources on electroless nickel plating.
  • A participant mentions that the purpose of the plating is to enhance wear resistance and notes that the supplier indicated successful plating on ferritic steel.
  • Several participants inquire about the application details, including wear conditions, cost considerations, and geographical context, suggesting that these factors may influence the choice of materials and coatings.
  • One participant speculates that the presence of molybdenum in SS316 may affect the plating process and suggests that a thin chrome plating might be a viable alternative.
  • Another participant shares their experience with various surface treatments, including hard chrome plating and a nickel-based coating, expressing skepticism about the effectiveness of electroless nickel plating for corrosion resistance on carbon steel.
  • It is noted that for steels with more than 5% chromium, a prior electrolytic nickel coating may be necessary for successful electroless plating.
Participants express multiple competing views regarding the effectiveness of electroless nickel plating on AISI 316 stainless steel, with no consensus reached on the reasons for the failures or the best alternative treatments.
Participants highlight the importance of understanding the specific application and conditions under which the plating is performed, as well as the potential influence of material composition on the plating process.
This discussion may be useful for engineers and materials scientists involved in surface treatment processes, particularly those working with stainless steels and seeking alternatives to electroless nickel plating.
gabriel
I need to cover a piece with electroless nickel plating on AISI 316, but for an unknown reason the process have failed several times. The supplier who have tried, told me that some times this happens in austenitic stainless steel but he does not know why. Does anybody know what could be the reason or what bibliography should I read?
Thanks a lot.
Thanks for the info. The reason is for increasing wear-resistant. The supplier told me that the process never failed in ferritic steel, so I wonder why this happen.
Hi gabriel,
What's your application? What is wearing, and what kind of surface pressures and velocities do you typically see? How often does this wear occur? Does this have to be dirt cheap or can the part afford to be made more expensive if the wear resistance is high? What country are you in and where are the parts made?
There are various alternatives to both material selection and surface coatings that might work well, but understanding the application is important.
I've heard of chrome plated SS304, but not SS316. I suspect the Mo has an effect. I believe SS316 is slightly more noble than SS304.
One might be able to apply a thin chrome plating to which Ni can be applied.
316L is used in nuclear reactor control elements where wear can be significant, and so they ion-nitride the surface. It has do be done correctly, otherwise the coating may result in higher corrosion.
Q_Goest said:
Hi gabriel,
The application is for ball valves, the part that I am talking about is the ball. We usually use ENP 0,025mm in carbon steel without problems. Regarding to your question, this process has been quoted, so it is not a problem. We are in Argentina. I think that the reason is related with the metallurgy, maybe the grain size or a right cleaning before the process maybe with an acid.
Thanks for the info. I'd rather not comment - you obviously know what you're looking for. Maybe Astronuc or someone else can help.
I'm just a bit curious why you want to go with ENP rather than a thin dense chrome plate or other proprietary surface treatments? I've tried using ENP for corrosion resistance on carbon steel, but it wasn't very effective. For wear resistance I've used hard chrome plate (cylinders) and http://www.magnaplate.com/coatings/nedox/index.shtml" SF-2 from General Magnaplate (valve poppet application). Both of these work very well in their specific applications. I believe Nedox is primarily a nickel based coating.
Thanks for your comments. Some process with chrome are not good for enviroments, so most of our customer do not accept it.
Just in case, someone could be interested in the reason, the process failed because in steels with %Cr greater than 5% is necessary a previous electrolitic coating with Ni. ;-)
  • · Replies 0 ·
  • · Replies 29 ·
13K
  • · Replies 0 ·
  • · Replies 19 ·
11K
