Solving a Rowing Kinematics Problem: Finding the Rate of the Current
The problem involves kinematics related to rowing, specifically determining the rate of the current affecting a rower's speed upstream and downstream. The original poster seeks assistance in solving the problem after encountering difficulties with their initial ideas.
  • Participants discuss setting up equations based on the relationship between speed, time, and distance for both upstream and downstream rowing. There is mention of defining variables for the current's speed and the distances traveled in each direction.
Some participants have provided guidance on formulating equations to represent the problem, while others reflect on their own challenges with the problem-solving process. There is a recognition of different approaches, but no explicit consensus has been reached.
The original poster expresses frustration with their attempts, indicating a potential struggle with the complexity of the problem. There is also a light-hearted exchange regarding simplifying problem-solving strategies.
Omid
A man who can row 4 miles per hour in still water finds that he can row upstream in 7 and 1/2 hours a distance which requires 2 and 1/2 hours to row downstream. Find the rate of the current.
When I saw the problem at once I had dozens of ideas to solve it but all of them failed.
Can you give me some hints ?
Thanks
The most direct way would be setting up the known equations and solve for them.
You have two unknowns, the speed of the current and the distance travelled.
You also have two linearly independent equations:
-The 'speed*time=distance' equation for going upstream
-The 'speed*time=distance' equation for going downstream
The speed when going upstream/downstream is just the speed of the man minus/plus
the speed of the current.
Let the current be v. Speed upstream is 4-v and the distance rowed in 7 and 1/2 hours is d= (4-v)(15/2). Speed downstream is 4+v and the distance rowed in 2 and 1/2 hours is (4+v)(5/2). Since those distances are the same, set them equal and solve for v.
I was making the problem harder and harder by using relative motion and vectors, ... that's why I couldn't solve it.
I must remember to kiss ( Keep It Simple and Straight forward) , as you did here, when solving physics problems.
Thank you very much
You mean it's not "Keep it simple, STUPID"? That's what people always tell ME!
:biggrin: :biggrin: :biggrin: :biggrin: :biggrin:
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 20 ·
