Derivation of equation for Phase-modulation fluorescence
  • Context: Graduate
  • Thread starter Thread starter McKendrigo
    Derivation Fluorescence
The discussion focuses on the derivation of equations related to frequency-domain lifetime measurements for fluorescent samples, specifically using sinusoidally-modulated light sources. The excitation function is defined as L(t) = a + b sin(ωt), where b/a = Ml represents the modulation of the excitation light. The intensity decay is modeled as I(t) = I₀ * exp(-t/τ), leading to the differential equation dI(t)/dt + (1/τ)I(t) = L(t), which incorporates the excitation function as a forcing term. The participants seek clarification on the derivation of this equation and the rationale for including L(t) instead of its derivative.
  • Understanding of sinusoidal functions and modulation techniques
  • Familiarity with fluorescence lifetime measurements
  • Knowledge of differential equations and their applications in physical systems
  • Basic principles of exponential decay in intensity measurements
  • Study the derivation of differential equations in the context of forced oscillations
  • Explore the principles of fluorescence lifetime spectroscopy
  • Learn about phase-modulation techniques in fluorescence measurements
  • Investigate the mathematical modeling of excited state populations in fluorescence
Researchers, physicists, and chemists involved in fluorescence spectroscopy, as well as students studying optical techniques in analytical chemistry.
McKendrigo
Hello there,
I'm going through the derivation for the equations relating to frequency-domain lifetime measurements for fluorescent samples. This is a technique whereby a sinusoidally-modulated light source excites a fluorescent sample, and the fluorescence lifetime of the sample, [tex]\tau[/tex] is found by relating [tex]\tau[/tex] to the phase shift and/or amplitude de-modulation of the fluorescence relative to the excitation source.
I'll go through the derivation up to the point I'm a little stuck!
Firstly, the excitation is given by:
[tex]L(t)= a + b sin \omega t[/tex],
where b/a = Ml is the modulation of the excitation light.
The fluorescence emission will respond to this excitation with the same frequency, but with a different phase shift and modulation. We assume that the excited state population of the fluorescent sample is:
[tex]N(t)= A + B sin(\omega t - \phi)[/tex],
The intensity, I(t), at any time is proportional to the number of molecules in the excited state N(t).
We suppose that the intensity decay following a delta-function excitation is a single exponential:
[tex]I(t) = I_{o}*exp(-t/\tau)[/tex]
Now - here comes where I come unstuck! - For a single exponential decay, the differential equation describing the time-dependent excited state population is:
[tex]{dI(t)}/{dt} = -{1/\tau}*I(t) + L(t)[/tex]
The textbook then goes on to substitute N(t) for I(t) in that equation, and find relationships between [tex]\tau[/tex] and the phase shift / de-modulation. The subsequent steps I'm fine with, I'm just not sure where this last equation comes from. I'm particularly unsure as to why you add L(t), rather than adding its derivative. If anyone could shed some light on how this equation must have been derived, I would be very grateful!
I'm way out of my area as far as your particular application is but here is my take, FWIW.
With your delta impulse the intensity I decreases exponentially according to your equation
[tex] \frac {dI(t)}{dt} +\frac 1 \tau I(t) =0[/tex]
giving the solution
[tex] I(t) = I_{o}*e^{-\frac t \tau}[/tex]
Now under the excitation L(t) you have a forcing function on the right side, much like the equation of a damped spring with a forcing function:
[tex] \frac {dI(t)}{dt} +\frac 1 \tau I(t) =L(t)[/tex]
Just my best guess. Probably I'd have to know the derivation of the DE in the first place to be sure.
That sounds entirely sensible to me. Thanks for your help!
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 0 ·
