What is the Scale Dependence of Coupling Constants in QFT?
  • Context: Graduate
  • Thread starter Thread starter PJK
    Scale
The coupling constant in Quantum Field Theory (QFT) is scale dependent, specifically influenced by the scale \(\mu\), which serves as a mathematical tool to regularize infinities at the loop level. Physical quantities must remain independent of this scale, indicating that the coupling 'constant' is actually a function of \(\mu\). According to Frank Wilczek, "hard" gluons couple weakly while "soft" gluons couple strongly, suggesting that the coupling can vary based on the momentum carried by the gluon in a Feynman graph. This scale is typically associated with the heaviest mass or invariant energy in the system, leading to logarithmic dependencies that are manageable in practice.
  • Understanding of Quantum Field Theory (QFT)
  • Familiarity with coupling constants and their roles in particle physics
  • Knowledge of Feynman diagrams and their interpretation
  • Basic concepts of regularization techniques in quantum physics
  • Study the concept of scale dependence in Quantum Field Theory
  • Read Wilczek's article on QCD for deeper insights into gluon interactions
  • Explore the implications of logarithmic dependencies in coupling constants
  • Investigate regularization methods used in QFT to handle infinities
Physicists, graduate students in theoretical physics, and researchers interested in the nuances of Quantum Field Theory and the behavior of coupling constants in particle interactions.
PJK
Hey,
the coupling constant in QFT is scale dependent. This scale \mu, it seems to me, is a mathematical tool used to regularize the infinities that arise at the loop level. Thus physical quantities have to be independent of this scale \mu. This implies that the coupling 'constant' is a function of \mu.
I read an article by Wilczek (http://www.frankwilczek.com/Wilczek_Easy_Pieces/298_QCD_Made_Simple.pdf) and it contains the following senctence:
'“Hard’’ gluons,
which carry a lot of energy and momentum, couple weakly;
whereas the less energetic “soft’’ gluons, couple strongly.'
I don't quite understand the justification why one can associate this mathematical, unphysical scale \mu with the very physical momentum of the gluon.
Does this mean that the coupling can have different values within a Feynman graph depending how much momentum is carried by its attached gluon?
Physicists often call some quantity a "constant", despite it is not a constant at all.
The scale is a typical heaviest mass or invariant energy carried by the system. It is not much better defined than an order of magnitude, however the dependences are at worse logarithmical so this is not a significant problem.
Yes.
