Thread Closed
Inelastic Collision
Share Thread Thread Tools
May14-10, 01:19 AM   #1
Inelastic Collision
A 10-g bullet moving at 1000 m/s strikes and passes through a 2.0 kg block initially at rest as shown in the diagram. The bullet emerges from the block with a speed of 400 m/s.
To what maximum height will the block rise above its initial position?
3. The attempt at a solution
It's not a perfectly inelestic collision since the bullet doesn't embed in the block. Therefore this is an inelastic collision. During the collision some momentum is conserved so,
Momentum just before = momentum just after
And I think:
Kenetic energy just after the collision = final potential energy
[tex]\frac{1}{2} 0.01 (1000)^2 = 2 (9.81) h[/tex]
[tex]h=253.5[/tex]
But this is FAR larger than the actual answer. What's wrong??
This is not a homework problem, just revision for my exam. So any help with this is really appreciated.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
May14-10, 01:26 AM   #2
Recognitions:
Homework Helper Homework Help
Bullet is traveling at 1000 m/s, passes through the block, and then comes out at 400 m/s.
So what will the change in kinetic energy be equal to?
May14-10, 01:27 AM   #3
Recognitions:
In your calculation you have not used the final velocity of the bullet.
Here change in KE = change in PE.
May14-10, 11:27 PM   #4
Inelastic Collision
In finding the change in Kenetic energy
[tex]\Delta E_K = \frac{1}{2}mv_{f}^2 - \frac{1}{2}mv_{i}^2[/tex]
So for initial mass should I use "mblock + massbullet", and for the final mass just use "mbullet", right? And do the same thing for change in PE?
May14-10, 11:40 PM   #5
Recognitions:
Change in KE of bullet = Change in PE of the block.
May15-10, 12:23 AM   #6
Recognitions:
Quote by rl.bhat View Post
Hang on. Bullet kinetic energy is not conserved. This is an inelastic collision. This is a conservation of momentum (collision) problem followed by an energy conservation (post-collision) problem.
AM
May15-10, 05:46 AM   #7
I'm confused... then what am I supposed to be doing?
May15-10, 07:23 AM   #8
Quote by roam View Post
Out of curiousity what's the nswer supposed to be?
May15-10, 11:02 AM   #9
Recognitions:
Apply conservation of momentum to the impact of the bullet on the block. Can you figure out what the block's speed is after the bullet passes through? How is the gain of momentum of the block related to the loss of momentum of the bullet? Can you work out the resulting speed of the block (immediately after the bullet passes through)? How much kinetic energy does the block have with such speed? What happens to that kinetic energy as the block rises? Can you work out from that how high the block rises?
AM
May15-10, 08:28 PM   #10
Quote by Andrew Mason View Post
AM
The velocity of the block immediately after the collision is
[tex]v=\frac{0.01 \times 1000}{2+0.01}=4.97[/tex]
Then do I use the equation (with initial gravitational potential =0)?
[tex]E_{Ki} + U_i = E_{Kf} + U_f[/tex]
The correct answer is supposed to be 46 cm.
May15-10, 09:04 PM   #11
Recognitions:
No. This is where you are going wrong. How much momentum does the bullet have before the collision? How much momentum does the block + bullet have afterward? So how much speed does the block have? Write out the equation. You know two of the three momenta so you can solve for the unknown block momentum.
Yes. Final kinetic energy is __?
Correct.
AM
May16-10, 05:09 AM   #12
If you apply the Principal of Conservation of Momentum, the momentum of the system before will equal the momentum after.
The momentum of the system before is just the momentum of the bullet, (0.01)(1000), while the momentum after is (0.01)(400) + 2V.
Solve this to get the velocity of the block, and apply the Principal of Conservation of Energy.
Thread Closed
Thread Tools
Similar Threads for: Inelastic Collision
Thread Forum Replies
inelastic collision Introductory Physics Homework 7
2D inelastic collision Introductory Physics Homework 5
An inelastic collision? Introductory Physics Homework 1
inelastic collision, please help Introductory Physics Homework 9
Mastering Physics: Collision on an incline plane and perfectly inelastic collision Introductory Physics Homework 2
