What's the best way to make a warm metal plate?
  • Thread starter Thread starter Poxnar
    Metal Plate
The discussion centers around methods for creating a warmable metal plate (70x45 cm) using electrical heating, specifically exploring options for battery-driven solutions. Participants consider various heating technologies and components suitable for the application.
  • Experimental/applied
  • One participant suggests using induction heating but expresses uncertainty about the best implementation method.
  • Another participant proposes using resistors attached to the back of the plate or adhesive warming pads, noting that power limitations exist when using a battery.
  • A question is raised about the required temperature and power, considering factors like insulation and external conditions (e.g., cold water).
  • A participant mentions needing enough power to melt snow, indicating a desire for significant heating capability.
  • One suggestion includes using tank or block heaters, which are typically used to prevent freezing in fuel tanks or greenhouses.
  • Another option presented is a heated pet bowl, which may serve as a practical solution for heating the plate.
Participants express various opinions on the best heating method, with no consensus reached on a single solution. Multiple competing views on heating technologies and their applicability remain evident.
Participants have not fully defined the specific power requirements or insulation conditions for the heating solution, which may affect the effectiveness of the proposed methods.
Poxnar
As the title says (and yes, I know it sounds a bit weird), what's the best way to make a warmable metal plate (70*45 cm big), using electrical warming? I've been thinking about using induction heating to make the plate warm, but I don't know the best way to do it. It should be battery driven and also have a switch, but that's basically the only components that I want the plate to have. So what's the best way to make it? And also, I would appreciate a simple circuit diagram.
A bunch of resistors bolted to the back of the plate, or you can buy adhesive warming pads that have a resistor spread through them.
Depends on how much power and who hot you need it to get - if you are running from a battery you aren't going to be able to heat it very much.
Ok, thanks for the tip.
How hot do you need and how much power - ie is the plate insulated or does it have cold water pouring over it?
I'll need power enough to melt snow on it, ie not that much power I guess. The warmer the better though.
Best way probably tank/block heaters.
Adhesive pads about 6x6 or 12x12 inches that put out about as much heat as a lightbulb. You use them to stop fuel tanks freezing or frost in greenhouses.
Something like this (http://www.kennedydiesel.com/detail.cfm?ID=372) you can also get smaller ones that run off a car battery.
Alright, I'll try that, thanks again for the help. :)
  • · Replies 37 ·
