Problem on my Final. pulling box with rope problem
  • Thread starter Thread starter J0hnnyD
    Box Final Rope
The problem involves a student pulling a box of books weighing 68 kg at an angle of 58 degrees above the horizontal, with a coefficient of kinetic friction of 0.27. The objective is to determine the acceleration of the box.
  • Participants discuss the forces acting on the box, particularly the normal force and its relationship to the angle of the rope. There are questions about how to calculate the normal force and the frictional force, considering the vertical component of the pulling force.
Participants are exploring the implications of the angle of the rope on the normal force and friction. Some express uncertainty about the lack of a defined pulling force, which complicates the ability to arrive at a definitive answer. There is an ongoing dialogue about the relationships between the forces involved.
There is a noted absence of a specific force value for the pull on the box, which leads to interdependent unknown variables in the discussion.
J0hnnyD
A student pulled a box of books weighing 68kg by a rope at an angle of 58 degrees above the horizontal plane of the floor. The floor has a coefficient of kinetic friction of µk=.27. What is the acceleration of the box of books?
∑F = ma
Force of friction = µk * Normal force
I chose the direction the box of books was being pulled to be positive. Then I summed up all the forces in the x direction and applied Newton's Law F=ma and solved for a.
∑Fx = Force from rope in the x direction - Force of friction = ma
∑Fx = 68*cos(58) - .27*(68 * 9.81) = (68)a
solve for a.
This problem was on my final yesterday so the numbers arent correct but is my reasoning and approach to this problem right? I thought i knew how to do these types of problems but the answer i was getting wasnt a choice on the test.
Thanks in advance.
Hi J0hnnyD! :smile:
The rope isn't horizontal, so the normal force will be less than mg. :redface:
tiny-tim said:
Hi J0hnnyD! :smile:
I thought to get the force of friction its always µk*N. what is the normal force then? mg minus the y component of the force of the rope?
Yea, exactly. The rope is pulling the box up a little, so the normal is actually less than mg.
Yes …
the reason is that the acceleration in the normal direction is zero, so all the components of force in that direction must add to zero. :smile:
I'm trying to understand this problem so if anyone could clarify.
But from what I am seeing here you really can't get a definite answer from
this problem because there is no force defined for the pull on the box,
so what you end up with is the Friction force depending on the pull in the
y direction which leads to unknown variables which depend on each other.
Somebody please explain to me if this is the case or I'm just not seeing something.
Hi jkerrigan! :smile:
jkerrigan said:
But from what I am seeing here you really can't get a definite answer from this problem because there is no force defined for the pull on the box,
ah, but novop :smile: didn't have the exact question in front of him when he posted …
solve for a.
This problem was on my final yesterday so the numbers arent correct …
… from the numbers in the posted (wrong) equation, we see that the pulling force was (by coincidence!) 68 N. :wink:
  • · Replies 38 ·
