Geometric Distribution problem
The discussion revolves around a problem involving a geometric distribution with a specified success probability. The original poster seeks to determine the largest value, y0, such that the probability P(Y > y0) is at least 0.1.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore different formulations of the probability and consider using summation and geometric series to find y0. There is a shift in approach suggested to consider the complementary probability P(Y < y0) instead.
The discussion is ongoing, with participants offering alternative methods and questioning the correctness of each other's formulations. Some guidance has been provided regarding the use of geometric series, but no consensus has been reached on the correct approach or final value for y0.
Participants are working under the constraints of the geometric distribution and are attempting to manipulate probabilities without complete information on the correct application of series summation.
FaradayLaws
Question:
If Y has a geometric distribution with success probability .3, what is the largest value, y0, such
that P(Y > y0) ≥ .1?
Attempt:
So i represented the probability of the random variable as a summation
Sum from y0= y0+1 to infinity q^(yo+1)-1 p ≥ .1
using a change of variables i let l = y0+1
p Sum from y0=l to inf (q)^l-1 ≥ .1
from here I'm stuck.. i was thinking of applying the partial sum for the geometric series but I'm not sure how to proceed from here.
Thanks!
It is easier to work from the other end. Find max y0 such that P(Y < y0) < .9. You will then have a finite sum (geometric series) to work with.
oh okay;
once working with the other end =>
summation from y0 =0 to y0-1 of q^y0-1 p < 0.9
with the change of variables l= y0-1
summation from l=0 to l of q^l p < 0.9
now finding the partial sum of the geometric series
p/(1-q) < 0.9
0.3/ 0.3 < 0.9
i'm stuck here ? how do i get the value for y0 ?
Your partial sum doesn't look right. It should be a function of y0. It should be something like 1-.3^(y0) < .9. (I am not sure whether it should be y0 or y0+1).
