Find equilibrium bond potential, given energy as a function of atomic separation
The problem involves finding the equilibrium bond potential in an ionic crystal, where the total cohesive energy is expressed as a function of the nearest neighbor distance between ions. The original poster attempts to differentiate the energy function with respect to distance to find the equilibrium condition.
  • Exploratory, Assumption checking
  • The original poster differentiates the cohesive energy function and sets the derivative to zero to find the equilibrium bond length. They express concern about a potential misstep in their substitution process leading to an incorrect result.
The discussion includes attempts to clarify the differentiation process and the substitution into the original formula. There is acknowledgment of a possible misprint in the question, which may affect the feasibility of finding a solution.
Participants note that the problem may contain a misprint, which raises questions about the validity of the calculations and assumptions made in the original statement.
knowlewj01
Given that the total cohesive energy, U, in an ionic crystal as a function of nearest neighbor distance, R, between two ions +e and -e is given by:
[itex]U(R) = \frac{A}{R^n} - \frac{\alpha e^2}{4 \pi \epsilon R}[/itex]
show that at equilibrium:
[itex]U(R) = \frac{\alpha e^2}{4 \pi \epsilon R}(1 - \frac{1}{n})[/itex]
differentiate U with respect to R and set to zero to find the equilibrium bond length and substitute it into the origonal formula. I think this is the right way to do it but i keep getting the wrong answer, here is my best attempt:
differentiate w.r.t. R and equate to 0:
[itex]\frac{dU}{dR} = 0 = -\frac{n A}{R^{n+1}} + \frac{\alpha e^2}{4 \pi \epsilon R^2}[/itex]
now rearrange to get:
[itex]\frac{n A}{R^{n+1}} = \frac{\alpha e^2}{4 \pi \epsilon R^2}[/itex]
Multiply through by R and divide through by n:
[itex]\frac{A}{R^n} = \frac{\alpha e^2}{4 n \pi \epsilon R}[/itex]
Notice that the term [itex]\frac{A}{R^n}[/itex] appears in the original formula, so substitute to get:
[itex]U(R) = \frac{\alpha e^2}{4 \pi \epsilon R}(\frac{1}{n} - 1)[/itex]
the 1/n and 1 are the wrong way round, i have a feeling its a problem with my substitution but i can't see it, anyone have any ideas?
//Edit: I have put in the correct latex code so you can see my calculations ;)
We cannot read your equations. Please try to use LateX.
ah, ok sorry about that ill try edit it
Nevermind, I just found out that this question was a misprint making it impossible. Thanks
  • · Replies 63 ·
  • · Replies 23 ·
