DC motor design calculations, help?
The original poster is tasked with constructing a brushed DC motor with specific requirements, including a rotational mechanical output power of 25W, a maximum current draw of 5A, and at least 3 poles in rotation. The motor must operate on a maximum of 30V DC and needs to be built and tested within a short timeframe.
  • The original poster attempts to identify relevant equations for calculating motor parameters, including back EMF and terminal resistance. They express confusion regarding the relationship between input power, efficiency, and voltage. Other participants question the clarity of the original poster's inquiry and suggest reformulating the question. Another participant seeks to determine the number of coils needed and the implications of using different wire gauges and magnetic field strengths.
The discussion is ongoing, with participants exploring various aspects of motor design, including torque, angular velocity, and the calculation of back EMF. Some guidance has been offered regarding the relationships between different parameters, but there is no explicit consensus on the methods to be used or the values required for calculations.
The original poster notes a lack of provided equations and expresses uncertainty about the resistance of the motor and how it changes with motion. There is also mention of assumptions regarding motor efficiency and the need for theoretical calculations before practical measurements can be made.
Michael31091
Hi, well my task is to construct a DC motor. With 25w rotational mechanical output power. It cannot draw more then 5A current, and has to have 3 or more poles in rotation. The motor must be brushed/commutated. There is a max of 30v D.C. input. The motor needs to be built and tested within a few days, so ill need calculations done by tomorrow (brutally tough i know)
I was not given relevant equations for the question, this is half my problem, id like some advise on which equations i should be using to caluclate the necessary parts to build the motor which will acomplish the goals stated above.
My attempt came up short when i came across the term 'back emf' or 'induced emf'. i found an equation:
Vo = IR + Ve
Where:
Vo = power supply
I = current
R = terminal resistance (is this calculatable for my question or do i need to build and measure this, and what exactly is this resistance? where is it found.. i thought it was the overall resistance of the motor)
Ve = Induced EMF (Back EMF)
Further continuation of this formual suggest substituing Ve = w Ke
Where:
w = angular velocity
Ke = Induced EMF constant (how do i determine this?)
In other attempts at solving this i came up with the following:
Pi = VI
Where:
Pi = power input (i assumed motor efficiency to be 50% as someone suggested this was a good idea, how does this affect other calculations, it should have more effect then just doubling the desired output getting an input power of 50w)
V = voltage
I = Current (as no more then 5A is allowed, i set this to 3A so I am well within the boundaries)
therefore i get voltage:
V = Pi/I
V = 50/3 = 16.67 Volts
As a DC power supply is used to power the motor, this should not be a problem?
I then attempted to find the resistance of the motor, thinking i could calculate the number of coils i needed.. evidently this led me no where as i used 'V=IR'. Apparently this resistance value is the resistance of the motor when not moving, resistance changes? I know a section of my research said that the current drawn by the motor is reduced the faster it spins. I don't know how or what I am calulating from here, can someone please help?
Can you reformulate your question to be a bit more clear and concise?
I would like to work out the number of coils i need to use in a 3 armature DC brushed motor, using AWG 24 wire, 3A ( can be up to 5 if needed), the magnets being used have B=1.25 T ( id also like to know if a stack of 4 would make 5T? ) The output of the motor must be 25W of mechanical rotational power (Power = torque x angular velocity)
Just updating, I've worked out how to calculate the Torque, and the Angular velocity. But to find the angular velocity i need the Back EMF, and I am still unsure as to how i can find this theoretically before i find the angular velocity? Also to find torque i need a value called 'Field density at end of pole (or armature)' and i assume this is just the field density caused by the input current in the coil of the armature, but i haven't been able to verify this yet.
so i ask, how do i work out the back emf, if i don't know angular velocity? or what other method can i use to find the angular velocity?
and when finding torque using 'T = Fr' where 'F = BIl', what is this B value and how is it calculated?
thankyou for helping!
  • · Replies 22 ·
  • · Replies 17 ·
