What is the force between two point charges at a 45 degree angle?
  • Thread starter Thread starter jimithing
    Electrostatic
The discussion revolves around calculating the force between two point charges positioned at a 45-degree angle relative to the horizontal. The participants explore the application of Coulomb's law and the decomposition of force into its components.
  • Mixed
  • Participants discuss the use of unit vectors to express the force between the charges, questioning the representation of force and the significance of signs in calculations. There is also exploration of the relationship between the forces acting on each charge.
The discussion includes attempts to derive the force components and clarify the signs associated with these components. Some participants confirm each other's reasoning, while others express uncertainty about the correct representation of forces and their components.
Participants are working under the constraints of a homework assignment, which may limit the depth of exploration and the information available for discussion.
jimithing
Point charges q1 and q2 are placed in space, with q1 at the origin and q2 a distance r from q1 making a 45 degree angle with the horizontal.
a) Find the force using unit vectors i and j from q1 to q2
b) " " from q2 to q1
c) If q1=q2, what is the magnitude of the force?
so far i have:
q2:
Fx = F cos (theta)
Fy = F sin (theta) - so F(1on2) = F cos(theta) i + F sin (theta) j
am I on the right track? and would F(2on1) be -F(1on2)?
jimithing said:
q2:
Fx = F cos (theta)
Why use F to represent the force? Use Coulomb's law and write "F" in terms of q1, q2, and r. Remember: signs matter.
Yes.
so for 1 on 2:
Fx = k(q1)(q2)cos(theta)/r^2 i
Fy = k(q1)(q2)sin(theta)/r^2 j
2 on 1
Fx = -k(q1)(q2)cos(theta)/r^2 i
Fy = -k(q1)(q2)sin(theta)/r^2 j
Part (c) when q1=q2=5 x 10^-6 C and r = 2.0 m
sub values into:
F = k (q1)(q2)/r^2 or F = kq^2/r^2
am i correct?
You are right!
jimithing said:
so for 1 on 2:
2 on 1
You are correct!
sub values into:
am i correct?
Sounds good to me.
Edit: I messed up the signs before! You are correct. :smile:
Doc Al said:
If the magnitude of the total force is F, where F = k(q1)(q2)/r^2,
then the components of the force on q1 are positive:
Fx = F cos(theta); Fy = F sin(theta)
and the components of the force on q2 are negative:
Fx = -F cos(theta); Fy = -F sin(theta)
Sounds good to me.
wouldn't the force of q1 on q2 be positive on the coordinate system used?
ok, assuming they attract.
got it.
Right. I messed up the signs before. (Funny... I was telling you to be careful of signs and I goofed up! :blush: )
Good work!
14K
