How to Calculate Buffer Volume for Given pH and Concentrations
  • Thread starter Thread starter Fibonacci
    Buffer Ph
The discussion centers on calculating the buffer volume required to achieve a specific pH using a 3.00 M HCO3- solution and a 0.200 M CO32- solution. The correct volume to be added is determined to be 13.96 mL. The calculation utilizes the Henderson-Hasselbalch equation, where pKa is given as 5.6e-11. The user initially miscalculated the required volume as 11.93 mL, indicating a misunderstanding in applying the mole ratios in the context of buffer solutions.
  • Understanding of the Henderson-Hasselbalch equation
  • Knowledge of buffer solution chemistry
  • Familiarity with pKa values and their significance
  • Basic skills in stoichiometry and mole calculations
  • Review the Henderson-Hasselbalch equation in detail
  • Study buffer solution preparation techniques
  • Learn about the significance of pKa in buffer systems
  • Practice stoichiometric calculations involving acid-base reactions
Chemistry students, educators, and laboratory technicians involved in buffer preparation and pH management in chemical experiments.
Fibonacci
am really stuck on this problem, can't seem to get to the right answer
How many mL of a 3.00 M HCO3- solution must be added to 200 mL of a 0.200 M CO32- solution to make a buffer with pH = 10.30?
Answer. 13.96 mL
pKa + log([base]/[acid])=pH
HCO3(-) --> H+ + CO3 (2-)
pH=10.3
pKa= 5.6e-11 (this value is give to us in our book)
0.048188 = log([base]/[acid])
1.117=[base/acid]
since the final volume cancels
we simply just use the mole ratios
let x be the mL of HCO3 - needed
base= (0.20)(0.2)
acid= 3x
1.117=0.2(0.2)/3x
x=11.933ml, which is way different to the actual answer
would appreciated heaps if someone could help
thanks
Must be error in the answer (or some typo in the data), 11.93mL seems to be correct.
methods
  • · Replies 16 ·
