NoPhysicsGenius
- 58
I am having difficulty with Problem 49 of Chapter 3 from Physics for Scientists and Engineers by Paul A. Tipler, 4th Edition:
In drawing the vector diagram for plane Q, we use the following equation:
[tex]\vec{v}_{Qg} = \vec{v}_{Qw} + \vec{v}_{wg}[/tex]
where [itex]\vec{v}_{Qg}[/itex] is the velocity of Plane Q relative to the ground, [itex]\vec{v}_{Qw}[/itex] is the velocity of Plane Q relative to the wind, and [itex]\vec{v}_{wg}[/itex] is the velocity of the wind relative to the ground.
Since I am unable to include a picture of the vector diagram, I will instead describe it as follows (and you might wish to draw it on a sheet of scratch paper for future reference):
In drawing the vector diagram for plane P, we use the following equation:
[tex]\vec{v}_{Pg} = \vec{v}_{Pw} + \vec{v}_{wg}[/tex]
where [itex]\vec{v}_{Pg}[/itex] is the velocity of Plane P relative to the ground, [itex]\vec{v}_{Pw}[/itex] is the velocity of Plane P relative to the wind, and [itex]\vec{v}_{wg}[/itex] is once again the velocity of the wind relative to the ground.
A description of the vector diagram for Plane P is as follows:
We note the following:
[tex]v_{wg} = 60 km/h[/tex]
[tex]\theta = 30'(\frac{1^\circ}{60'}) = 0.5^\circ[/tex]
[tex]v_{Qw} = v_{Pw}[/tex]
[itex]t_Q = t_P - 1 h[/itex], where [itex]t_Q[/itex] is the time of arrival of Plane Q and [itex]t_P[/itex] is the time of arrival of Plane P.
[itex]\vec{v}_{wg}[/itex] is computed as follows:
[tex]v_{wg,y} = v_{wg} \cos \theta = (60 km/h) \cos 0.5^\circ = 60 km/h[/tex]
[tex]v_{wg,x} = v_{wg} \sin \theta = (60 km/h) \sin 0.5^\circ = 0.524 km/h[/tex]
Therefore, [itex]\vec{v}_{wg} = v_{wg,x} \widehat{i} + v_{wg,y} \widehat{j} = (0.524 \widehat{i} + 60 \widehat {j}) km/h[/itex].
So far, so good.
Here's where things start to get potentially troublesome ...
From the vector diagram for Plane P, we have:
[tex]v_{Pw,x} = -v_{wg,x} = -0.524 km/h[/tex]
From the vector diagram for Plane Q, we have:
[tex]v_{Qw,x} = -v_{wg,x} = -0.524 km/h[/tex]
Now ...
[tex]\sin \theta_Q = \frac{opposite}{hypotenuse} = \frac{|v_{wg,x}|}{v_{Qw}}[/tex]
[tex]\Rightarrow v_{Qw} = \frac{|v_{wg,x}|}{\sin \theta_Q} = \frac{0.524 km/h}{\sin \theta_Q}[/tex]
Also ...
[tex]\sin \theta_P = \frac{opposite}{hypotenuse} = \frac{|v_{wg,x}|}{v_{Pw}}[/tex]
[tex]\Rightarrow v_{Pw} = \frac{|v_{wg,x}|}{\sin \theta_P} = \frac{0.524 km/h}{\sin \theta_P}[/tex]
The condition [itex]v_{Pw} = v_{Qw}[/itex] implies:
[tex]\frac{0.524 km/h}{\sin \theta_P} = \frac{0.524 km/h}{\sin \theta_Q}[/tex]
[itex]\Rightarrow \theta_P = \theta_Q[/itex] (for our purposes, at least--though the angles can actually differ by certain fractional multiples of [itex]\pi[/itex], though I forgot the exact formula ...)
With [itex]\vec{r}_{Qg}[/itex] denoting the position vector of Plane Q relative to the ground and [itex]\vec{r}_{Pg}[/itex] denoting the position vector of Plane P relative to the ground, we have the following conditions:
[tex]r_{Qg,y} = v_{Qg,y}t_Q = 624 km[/tex]
[tex]r_{Pg,y} = v_{Pg,y}t_P = -624 km[/tex]
The condition [itex]r_{Pg,y} = -r_{Qg,y}[/itex] yields:
[tex]v_{Pg,y}t_P = -v_{Qg,y}t_Q[/tex]
The relation [itex]t_Q = t_P - 1[/itex] then yields:
[tex]v_{Pg,y}t_P = -v_{Qg,y}(t_P - 1)[/tex]
[tex]\Rightarrow (v_{Pg,y} + v_{Qg,y})t_P = v_{Qg,y}[/tex]
[tex]\Rightarrow t_P = \frac{v_{Qg,y}}{v_{Pg,y} + v_{Qg,y}}[/tex]
From the vector diagram for Plane Q ...
[tex]v_{Qg,y} = v_{Qw,y} + v_{wg,y} = v_{Qw,y} + 60[/tex]
Now ...
[tex]\cos \theta_Q = cos \theta_P = \frac{adjacent}{hypotenuse} = \frac{|v_{Qw,y}|}{v_{Qw}}[/tex]
[tex]\Rightarrow |v_{Qw,y}| = v_{Qw} \cos \theta_Q = v_{Pw} \cos \theta_P[/tex]
Therefore ...
[tex]v_{Qg,y} = v_{Pw} \cos \theta_P + 60[/tex]
Now ...
[tex]v_{Pg,y} = v_{wg,y} + v_{Pw,y}[/tex]
Since [itex]v_{Pw,y} = -v_{Qw,y}[/itex], we then have:
[tex]v_{Pg,y} = v_{wg,y} - v_{Qw,y} = 60 - v_{Pw} \cos \theta_P[/tex]
Therefore ...
[tex]t_P = \frac{v_{Qg,y}}{v_{Pg,y} + v_{Qg,y}} = \frac{v_{Pw} \cos \theta_P + 60}{(60 - v_{Pw} \cos \theta_P) + (v_{Pw} \cos \theta_P + 60)}[/tex]
[tex]\Rightarrow t_P = \frac{v_{Pw} \cos \theta_P + 60}{120}[/tex]
Then [itex]v_{Pw} = \frac{0.524}{\sin \theta_P}[/itex] implies:
[tex]t_P = \frac{0.524 \cot \theta_P + 60}{120}[/tex]
I haven't the slightest clue where to go from here.
The answer in the back of the book is as follows:
There is at least one problem with this answer ... Obviously, although the two planes might well have the same angle of heading (as I have shown above), it is obvious from the vector diagrams that the heading of Plane Q would be [itex]6.58^\circ[/itex] west of north, whereas the heading of Plane P would be [itex]6.58^\circ[/itex] west of south.
Also, I should note the following:
[itex]v_{Pw} = \frac{0.524 km/h}{\sin \theta_P} = \frac{0.524 km/h}{\sin 6.58^\circ} = 4.57 km/h \ll[/itex] the correct answer of [itex]261.7 km/h[/itex].
Additionally, note the following discrepancy:
[tex]t_P = \frac{v_{Pw} \cos \theta_P + 60}{120} = \frac{261.7 \cos 6.58^\circ + 60}{120} = 2.67 h \neq \frac{0.524 \cot \theta_P + 60}{120} = \frac{0.524 \cot 6.58^\circ + 60}{120} = 0.538 h[/tex]
Indeed, if the value on the right (namely, [itex]0.538 h[/itex]) were correct, then [itex]t_Q = t_P - 1 h = 0.538 h - 1 h = -0.462 h[/itex]!
Clearly, I have done a great deal wrong here. Can someone please spot the flaw(s) in my reasoning?
Airports A and B are on the same meridian, with B 624 km south of A. Plane P departs airport A for B at the same time that an identical plane, Q, departs airport B for A. A steady 60 km/h wind is blowing from the south 30' east of north. Plane Q arrives at airport A 1 h before plane P arrives at airport B. Determine the airspeeds of the two planes (assuming that they are the same) and the heading of each plane.
[itex]\vec{v}_{Qg}[/itex] points from due south to due north;
[itex]\vec{v}_{wg}[/itex] points from the tail of [itex]\vec{v}_{Qg}[/itex] toward the northeast;
[itex]\theta[/itex] is used to denote the angle between [itex]\vec{v}_{Qg}[/itex] and [itex]\vec{v}_{wg}[/itex], which is 30' east of north;
[itex]\vec{v}_{Qw}[/itex] points from the head of [itex]\vec{v}_{wg}[/itex] to the head of [itex]\vec{v}_{Qg}[/itex], in a direction west of north;
[itex]\theta_Q[/itex] is used to denote the angle of the heading of Plane Q. It is located between [itex]\vec{v}_{Qw}[/itex] and a line drawn from the tail of [itex]\vec{v}_{Qw}[/itex] parallel to [itex]\vec{v}_{Qg}[/itex]. Note that, by interior angles, [itex]\theta_Q[/itex] is also the angle between [itex]\vec{v}_{Qg}[/itex] and [itex]\vec{v}_{Qw}[/itex].
[itex]\vec{v}_{Pg}[/itex] points from due north to due south;
[itex]\vec{v}_{wg}[/itex] points from the tail of [itex]\vec{v}_{Pg}[/itex] toward the northeast;
[itex]\theta[/itex] is used to denote the angle between [itex]\vec{v}_{wg}[/itex] and a line drawn parallel to [itex]\vec{v}_{Pg}[/itex], which is 30' east of north;
[itex]\vec{v}_{Pw}[/itex] points from the head of [itex]\vec{v}_{wg}[/itex] to the head of [itex]\vec{v}_{Pg}[/itex], in a direction west of south;
[itex]\theta_P[/itex] is used to denote the angle of the heading of Plane P. It is located between [itex]\vec{v}_{Pw}[/itex] and a line drawn from the tail of [itex]\vec{v}_{Pw}[/itex] parallel to [itex]\vec{v}_{Pg}[/itex]. Note that, by interior angles, [itex]\theta_P[/itex] is also the angle between [itex]\vec{v}_{Pg}[/itex] and [itex]\vec{v}_{Pw}[/itex].
So far, so good.
Now ...
Also ...
Now ...
Therefore ...
Now ...
Therefore ...
[itex]261.7 km/h[/itex], [itex]6.58^\circ[/itex] west of north
